New Wheel Setup
Subscribe
Feb 26, 2019 | 02:35 PM
Hey what's up everyone! So I have the opportunity to snag these wheels for $350 with the tires on them. They are 18x8 5x114.3 +40 wrapped in 225/35R18s. The only issue I know of is that the center bore on these is 73.1 and the TL hub is 64.1. I could just get some aluminum hubcentric rings though and I shouldn't have any issues. My only question is, with those tires at stock height would I have any issues until I'm able to buy thicker tires?
And yes, there are 4. The other one isnt in this picture.
Reply 0
Feb 26, 2019 | 04:44 PM
Aside from a slightly rougher ride and speedometer error, you shouldn't experience any other issues.
Reply 0
Feb 26, 2019 | 06:49 PM
Quote: Aside from a slightly rougher ride and speedometer error, you shouldn't experience any other issues.
Lol I'm a wheel newbie... definitely didnt even think about the speedometer. Is that cause the wheels are an inch bigger or cause the tires are smaller?
Reply 0
Feb 26, 2019 | 07:55 PM
Tires being smaller....
Reply 0
Feb 27, 2019 | 09:20 AM
Okay thank you! That's what I thought but I honestly wasnt sure. Learning a little bit everyday Haha
Reply 0
Feb 27, 2019 | 09:24 AM
The correct size tire for those wheels would be 235/40 R18; the 225/35s are too small both in terms of tread width and diameter; ain't no way I'd ever put those on my TL.
Reply 0
Feb 27, 2019 | 09:27 AM
Quote: The correct size tire for those wheels would be 235/40 R18; the 225/35s are too small both in terms of tread width and diameter; ain't no way I'd ever put those on my TL.
I wouldn't run them for long. Theres not much tread anyways. But I'd probably get 245/40R18... that's what I've got on my aspec wheels on my 06 TL. Any benefits to getting 235/40 over 245/40?
Reply 0
Feb 27, 2019 | 09:39 AM
Quote: I wouldn't run them for long. Theres not much tread anyways. But I'd probably get 245/40R18... that's what I've got on my aspec wheels on my 06 TL. Any benefits to getting 235/40 over 245/40?
The benefit of the 235/40 R18s is they are the correct size for your car; going with 245/40 R18 size tires will induce speedometer and odometer error (you'll be traveling a bit faster and further than indicated).
Reply 0
Feb 27, 2019 | 09:52 AM
Quote: The benefit of the 235/40 R18s is they are the correct size for your car; going with 245/40 R18 size tires will induce speedometer and odometer error (you'll be traveling a bit faster and further than indicated).
You're right. Could've sworn when I looked up the Aspec tire size everywhere said 245 and not 235. Well, I haven't had any issues so far and I know Waze isnt the best reference for speedometer but Waze says I'm going the same speed as the speedo on the car. The miles I think is the bigger issue. Well fudge. Anyways, the wheels I were going to buy have been sold so I'm not getting those ones anyways.
Reply 0
Feb 27, 2019 | 05:39 PM
Quote: You're right. Could've sworn when I looked up the Aspec tire size everywhere said 245 and not 235. Well, I haven't had any issues so far and I know Waze isnt the best reference for speedometer but Waze says I'm going the same speed as the speedo on the car. The miles I think is the bigger issue. Well fudge. Anyways, the wheels I were going to buy have been sold so I'm not getting those ones anyways.
what do you mean by "the miles I think is the bigger issue"?
Reply 0
Feb 28, 2019 | 05:48 AM
Quote: what do you mean by "the miles I think is the bigger issue"?
Inccurate odometer
Reply 0
Feb 28, 2019 | 10:20 AM
I believe it will be negligible. I went with 245/40 on my aspec’s for a littler more width and rim protection.
Reply 0
Feb 28, 2019 | 10:49 AM
The math says:
  • 235/45 R17 -- Sidewall Height: 4.1634" -- Diameter: 25.3268" -- Circumference: 79.5664" -- Tire Revs/Mile: 796.32
  • 235/40 R18 -- Sidewall Height: 3.7008" -- Diameter: 25.4016" -- Circumference: 79.8014" -- Tire Revs/Mile: 793.97
  • 245/40 R18 -- Sidewall Height: 3.8583" -- Diameter: 25.7165" -- Circumference: 80.7909" -- Tire Revs/Mile: 784.25
Reply 0
Mar 1, 2019 | 09:29 AM
No mention of how the oem tires that came on the car, 235/45r17 were oversized at 25.5 or 25.6 inches in diameter? I remember reading that somewhere on this forum.
Reply 0
Mar 1, 2019 | 12:38 PM
Quote: No mention of how the oem tires that came on the car, 235/45r17 were oversized at 25.5 or 25.6 inches in diameter? I remember reading that somewhere on this forum.
Not sure what you're saying, 234/45 R17 tires are by definition within two tenths of an inch in diameter either way of 25.4"; said another way, a new tire at 25.6" is still considered within spec.
Reply 0
Mar 6, 2019 | 10:46 AM
I run 255/40/17 on all corners with the stock 17' waffles without issue. I also have a considerate amount of drop
Reply 0
Subscribe
