Need info with TPMS On TL 05 rims
Old 10-21-2010, 02:04 PM
8th Gear
civic1990si's Avatar
Hi all,
Hi have a TL type S 07 and i bought some TL 05 5 spoke rims. I want to know if i can install TPMS on that rims. I know they don't come with TPMS. I go check the fit in a acura dealer. The things that bugging me is the TPMS from a TL type s once installed is loose. So i'm affraid the TPMS will be damage once a day. Is someone of you run these rims with TL TPMS? Did you do something special for the installation?
Sorry for my english guys i come from quebec
Old 10-21-2010, 06:53 PM
06 Anthracite TL
erdoc48's Avatar
I have pre-06 factory rims as my winter set, and TPMS monitors fit easily and without any modifications to the rim.
Short answer...yes.
Old 10-22-2010, 04:48 AM
8th Gear
hi,
thanks for the reply. Did you install yourself the TPMS in the rims? Once the TPMS is scread, the unit inside the rims is it free? Cause the TL TPMS is swevel about the things we use to put air in the rims.
Old 10-22-2010, 09:30 AM
06 Anthracite TL
erdoc48's Avatar
They are solidly mounted- Goodyear did it for me and it was apparently no big deal for them, no swiveling or movement noted.
Old 10-22-2010, 10:07 AM
DMZ
Head a da Family
DMZ's Avatar
They do fit, yes, but the spacing around the valve stem from '06 wheels on is 'supposed' to make removing and installing the TPMS sensors easier.
Old 10-22-2010, 12:54 PM
8th Gear
Hi guys,
You are right, it's fits. The swiveling was because the guys at acura doesn't scread the vavle properly on the TPMS
Thanks for your helps
MrHeeltoe
20
02-23-2023 01:54 PM
Gout
11-02-2015 12:22 AM
RobbDizzle
10-15-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Need info with TPMS On TL 05 rims
