Lower control arm rubber bushing is cracking
Old 10-15-2018, 06:38 PM
VictorTL's Avatar
hi. I discovered the lower control arm rubber bushing has a crack. Is a super bonding glue can fix this?
Old 10-15-2018, 06:39 PM
Received 8,597 Likes on 6,640 Posts
no. replace it. It's a common issue on our car
Old 10-15-2018, 06:57 PM
VictorTL's Avatar
Probably it costs arms and legs to have it replaces at the dealer. How hard is it to do it yourself?
Old 10-15-2018, 07:00 PM
Have you tried searching? It's called compliance bushings and a lot of people have DIY'd them. https://www.google.com/search?q=diy+...hrome&ie=UTF-8
There's also an EXCELLENT how to: https://acurazine.com/how-tos/a/acur...ushings-423775
Old 10-16-2018, 09:09 AM
flyromeo3's Avatar
There are a total of 2 bushings on the lower control arm.
You can either replace them by removing the LCA and taking it to a auto body shop and have them press out the bushing and put new ones in
OR
buy new control arms. You will have to do both sides even if one is broken.
Just note removing the lower ball joint is going to be a bitch if you've never done it before and if you do tackle this job just make sure to buy lower ball joints.
In my case, I ended up replacing both lower control arms.
Old 10-17-2018, 11:16 AM
VictorTL's Avatar
The lower ball joint is not part of the LCA but they connected together?
Old 10-17-2018, 11:49 AM
BreezyTL's Avatar
That is correct. The ball joint is pressed in to the knuckle.
Old 10-17-2018, 06:32 PM
VictorTL's Avatar
Ok thanks
Old 11-21-2018, 07:53 PM
tpz76's Avatar
Just buy new arms and be done with it. way easier.
dr-who
10-03-2023 07:34 PM
gamekiller04
08-09-2014 03:28 PM
thorws
01-04-2014 01:33 AM
craigerd2
03-28-2009 03:11 PM
drewha174
11-20-2001 11:13 AM
Quick Reply: Lower control arm rubber bushing is cracking
