Installed my first mod
Old Jan 17, 2010 | 09:06 PM
jtsangAZ's Avatar
Stop Drop and Roll
A Progress RSB. Feels good man
Old Jan 17, 2010 | 09:18 PM
05AcTL's Avatar
Old Jan 17, 2010 | 10:22 PM
CLtotheTL32's Avatar
Congrats man! What else is on your to-do list?
Old Jan 18, 2010 | 12:13 AM
Souljah's Avatar
Former Whiner
Nice! This guy is for you!
Souljah's Avatar
Former Whiner
What's next meng?
Old Jan 18, 2010 | 12:14 AM
TLin401's Avatar
'13 Hyundai Sonata
Old Jan 18, 2010 | 12:20 AM
Souljah's Avatar
Former Whiner
^Progress RSB Tho?
It's not even powder coated or anything.
Old Jan 18, 2010 | 12:22 AM
07TLFIXITUP's Avatar
2012 TL Tech
Rsb??
Old Jan 18, 2010 | 12:24 AM
Souljah's Avatar
Former Whiner
Rear Sway Bar
Old Jan 18, 2010 | 12:28 AM
TLin401's Avatar
'13 Hyundai Sonata
Originally Posted by Souljah
^Progress RSB Tho?
Why not though?
We all love pics here.
Old Jan 18, 2010 | 12:32 AM
Souljah's Avatar
Former Whiner
True true! Show us that beautiful TL!
Old Jan 18, 2010 | 02:13 AM
jtsangAZ's Avatar
Stop Drop and Roll
Next on the list is neuspeed supercup or some coilovers, but that probably wont happen till I move back to Arizona.
And about them pics....i bought a used rsb from a member here and didn't bother taking pics during the install. It was raining and it was an in and out job. Total install time was less than an hour.
But damn...does it feel good to make the turns
Old Jan 18, 2010 | 03:08 AM
Souljah's Avatar
Former Whiner
Yes.. yes it does.
I love it.
I'm sure you'll do research but the TEIN SS are nice. May be a little overpriced in my opinion. But do it!
Old Jan 18, 2010 | 10:40 AM
pwr2panda's Avatar
isnt there a chance that it'll crack open the subframe? i really wanted to get a RSB but reading threads about it scared me...prolly gonna go for TL-S OEM RSB
Old Jan 18, 2010 | 10:44 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Only if you upgrade the bushings, but even then there's only a small chance. I've NEVER heard of this happening to anybody yet.
Old Jan 18, 2010 | 11:05 AM
GoldnKnight22's Avatar
OOOOOH
Yes.. yes it does.
I love it.
All I can say to that is.................
http://www.6thgenaccord.com/forums/s...ad.php?t=25734
3G TL's are welcome to this groupbuy, btw
First ever legit unmodified AMR coilovers.
Old Jan 18, 2010 | 02:43 PM
jtsangAZ's Avatar
Stop Drop and Roll
That sounds enticing. But are there any other AZ members on here that has this set up? and I'm pretty noob at mods so whats a "unmodified coilover" vs a modified coilover or other coilovers say from H&R or Tein?
Old Jan 18, 2010 | 05:50 PM
NOTSKERDD's Avatar
You can also shave your drivers side door handle. $10.00 mod,takes away the key hole and it comes painted.
Old Jan 18, 2010 | 06:02 PM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
^how do u do that?
Old Jan 18, 2010 | 07:15 PM
Bender's Avatar
you pull off the plastic piece and put the one you bought on.
Old Jan 18, 2010 | 07:59 PM
pmurray12002's Avatar
5th Gear
Old Jan 19, 2010 | 09:55 AM
OOOOOH
AMR's have never been made for TL's until now. Simply because they didn't design the top mount with the TL's bolt pattern until I talked to the owner of the company and told him they are the exact same as the 7G Accord setup except different top mount bolt pattern.
So currently, if you wanted to use a set of coilovers not specifically made for the TL, you would have to grind off a bolt from the top mount or drill through your strut tower. That's what I meant by unmodified vs modified to work for the TL.
There may be a few people with AMR's that they've made work, but I couldn't tell you who. But no one has this legit version yet.
It's only a matter of time until the Tein SS's will be just another second rate coilover, guys. Just wait til TL owners get their hands on these.
They've never once had a customer report a blown shock. In 6+ years.
Sorry for kinda going off-topic but I thought it was important, haha.
Old Jan 19, 2010 | 08:32 PM
jtsangAZ's Avatar
Stop Drop and Roll
That sounds like a lot of work to install some coilovers so hopefully when I am ready to buy them they might have a setup specifically made for the 3g TL. Thanks for putting AMR on my radar.
Old Jan 20, 2010 | 02:16 PM
ttribe's Avatar
I've been running a Comptech RSB for more than 3 years now with no problems whatsoever.
Old Jan 20, 2010 | 02:23 PM
Bender's Avatar
I have read where some peeps think the CT bar is ideal where others go bigger with the progress. I have also read where bigger is not necessarily better in terms of real end sliding on tight turns due to the thickness of the bar. What are your thoughts on how thick the rear bar should be?
Old Jan 20, 2010 | 03:19 PM
ttribe's Avatar
I don't really have anything else to compare it to (in terms of other, thicker RSB's), but I can tell you that I noticed an immediate and profound difference when I upgraded from the stock RSB on an '06 5AT to the CT bar. So, from that standpoint, an increase in the thickness of the bar was a good move...what I don't know is whether the CT bar is optimal or not. I wish I could provide more insight there.
I will elaborate thought and mention that the handling was further improved when I added the A-Spec suspension and high performance tires (Goodyear Eagle F-1 GS-D3's). This combination has completely changed the handling characteristics of this car. As you know, it's a relatively heavy sedan, and I can safely take corners in it at much higher than normal speeds...never managed to break the back-end loose.
Old Jan 20, 2010 | 09:39 PM
jtsangAZ's Avatar
Stop Drop and Roll
I agree too. Going from the stock 5at bar to the progress bar has a night and day difference. Also upgrading from the stock michelins to some summer tires (yoko s.drives) helped a bit. I can't wait for some springs/shocks/coilovers to see how much more the handling will do.
oo7spy
Jun 19, 2023 12:48 AM
youngTL
5G TLX Performance Parts & Modifications
55
May 23, 2020 07:39 AM
TLDude876
Dec 28, 2016 03:18 PM
BoricuaTL
Apr 8, 2016 01:08 PM
eastcoastguy
Sep 24, 2015 02:07 PM
