View Poll Results: Do you have Nitrogen
Yes
18.06%
No
47
65.28%
Why Nitrogen ?
16.67%
Voters: 72. You may not vote on this poll
Got Nitrogen ?
Old Sep 30, 2005 | 04:36 PM
kcrumbley's Avatar
Question Got Nitrogen ?
Who here is running Nitrogen in your tires ??
Old Sep 30, 2005 | 04:43 PM
PoochaKannInc's Avatar
Shift_faster
I would say no one...
edit:
because I don't think the benefits outweigh the cost.
Old Sep 30, 2005 | 04:45 PM
NFLblitze1's Avatar
Youse Gots Sacked
Nitrogen in ur tires?!??! ive never heard of that....that seems like it could be dangerous...one spark and a popped tire....KABOOM!
Old Sep 30, 2005 | 04:51 PM
Shift_faster
^ Actually it is not dangerous.
Old Sep 30, 2005 | 04:53 PM
rsc123az's Avatar
Umm, I think you're getting Nitrogen and Hydrogen confused. Nitrogen is non-flammable. Don't they require chemistry in high school anymore? But to answer the original question, no, I'm not. We used it in aircraft tires in the Air Force, but the reasons for doing so don't really apply to cars for the most part. It's just a marketing gimmick.
Lance
Old Sep 30, 2005 | 05:09 PM
NFLblitze1's Avatar
Youse Gots Sacked
how does it affect a car handling wise? sorry about that.....brain fart
Old Sep 30, 2005 | 05:14 PM
Neumahn's Avatar
It has nothing to do with the handling, it is a marketing gimmick. They charge you a pile of money to put nitrogen in your tires because in theory it will leak less because nitrogen molecules are larger than oxygen molecules. In reality even if the theory is true after you top off your tires a few times they end up naturally being mostly nitrogen. Stay away from this waste of money.
Old Sep 30, 2005 | 05:16 PM
TurboSam's Avatar
Big Brother is Watching..
i say put helium in your tires to make your car lighter
Old Sep 30, 2005 | 05:19 PM
Pure Adrenaline's Avatar
Dragging knees in
It's not really about leaking. Nitrogen expands and shrinks less than oxygen dependent on the ambient temperature. So you won't have to worry about high pressure during the summer or low pressure in the winter, as much as with regular air.
Technically, everybody is already running approximately 60% nitrogen in their tires, since "air" is mostly nitrogen.
However, when I got a set of new tires for the family beater, CostCo filled up the tires with 100% pure nitrogen and since it was included in the already low price, it was a nice bonus.
Old Sep 30, 2005 | 06:15 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
Race tires are filled with nitrogen as a way to keep the pressure more constant as the tires heat up, but I have never thought anyone would bother with their daily driver.
Old Sep 30, 2005 | 07:23 PM
kcrumbley's Avatar
Nitrogen has multiple benefits
1. Less expansion & contraction
2. No moisture (You chrome wheel guys NO Corrosion) Wouldn't that be nice.
3. Denser in molecules so you dont lose air pressure as easy (Less rolling resistance) Better GAS Mileage..
Just a few benefits.
Old Sep 30, 2005 | 07:25 PM
NFLblitze1's Avatar
Youse Gots Sacked
how expensive is it?
Old Sep 30, 2005 | 08:10 PM
kcrumbley's Avatar
Should be no more than $3.00 per tire and that should be for the life of the tire.
Old Sep 30, 2005 | 09:54 PM
Shoot2Thrill's Avatar
Walk the walk
A 6k bottle of N2 costs about 40 bucks so some genius can figure out how many tires that fills but needless to say at 3 bucks a tire it's great business. Some marketing guru/engineer/accountant figured out it cheaper than maintaining a compressor.
Old Sep 30, 2005 | 09:59 PM
NFLblitze1's Avatar
Youse Gots Sacked
shoot2Thrill....man where in morristown are u from?
Old Sep 30, 2005 | 10:06 PM
Neumahn's Avatar
Actually everybody is already running about 78% nitrogen and I have yet to see any tests that show this is nothing more than theory being used to add to profits. Sounds feasible but probably hads no measurable effect.
Old Sep 30, 2005 | 10:13 PM
Walk the walk
you asked the question before, just up froom Greystone.
Corrosion? On the TL the wheels are aluminum which by itself is somewhat corrosion resistant further, most likely anodized before painting and it they are chrome plated thats a surface treatment that should make them more robust against moisture/humidity. Especially on the inside of the tire, I have never seen a inside of an aluminum wheel oxided. I won't say that that it never happened but it surely is not a epidemic. The road salt on the outside is a far more challenging.
Plus, dry air is another option but that doesn't sound as high tech.
Note :if it chrome plated that anodizing must be removed, so you might deal with adhesion between the aluminum and the chromium or strike material
Old Oct 3, 2005 | 01:39 AM
triggle's Avatar
'04 6mt Pearl
We have a Costco nearby that uses N2 instead of air. Might be worth a call.
Old Oct 3, 2005 | 01:53 AM
triggle's Avatar
'04 6mt Pearl
I was under the impression that the N2 won't OXIDIZE the rubber. I can only assume oxidization would contribute to cracking or hardening of the rubber. Since AIR contains O2 it will oxidize whatever it comes into contact with.
Old Oct 3, 2005 | 06:19 AM
svtmike's Avatar
Costco put the new tires on my wife's car, and finished the inflation with Nitrogen. It's not 100% pure because there was air in the tire before inflation. Then they put hideous green valve cover stems on .
I think it's just . I've never had a problem with oxidation of my tires, and I've never had a problem with too extreme swings in tire pressure with the weather. The larger molecules theory is a joke - if the gaps that air leaks out of tires through were molecular in size, then the nitrogen molecules would just clog them up and seal them off anyway.
Mike
Old Oct 7, 2005 | 01:52 PM
kcrumbley's Avatar
Out of all the people here this is all that voted ??
Old Oct 7, 2005 | 03:07 PM
Walk the walk
This is actually a very good point and since the tire inflation is only going up about 2.5 atmospheres or so, it illustrates the whole notion is a joke.
Old Oct 12, 2005 | 04:15 PM
kcrumbley's Avatar
A joke if you like chrome peeling on your wheels..... Nice mascara...
It has been tested if you can do some research.
Old Oct 13, 2005 | 04:29 PM
Cocoa's Avatar
2600lb CL
Nitrogen is used usually in cars that people auto cross in. The reason being is so that handling isn't affected as much when the tires get too hot after running them hard for a period of time.
For the most part, with Nitrogen the change in psi pressure would be around a 2-3psi increase after running the tires hard at the tracks, as opposed to a 6-8psi increase with oxygen/nitrogen combo. That was the reason I have learned as to why to use it.
Old Oct 13, 2005 | 04:31 PM
Cocoa's Avatar
2600lb CL
tire pressure affects handling, so that is why you would want to remain with constant tire pressure throughout the race, and not have your tires slightly over inflat due to expansion from molecules...
Old Oct 17, 2005 | 10:38 PM
Walk the walk
Calculating using the gas equations I say it would be very optimistic to have even a 1 PSIG difference under extreme conditions. Nitrogen = HOT AIR
Old Oct 30, 2005 | 01:01 AM
jazzpicker's Avatar
Remember the Hindenburg
I think the dangerous gas is hydrogen also stay away from methane.
Old Nov 22, 2005 | 04:05 PM
kcrumbley's Avatar
Come on now lets get the poll results up there I know more people have looked at this thread.
Old Nov 22, 2005 | 04:16 PM
jbcritch's Avatar
Old May 18, 2006 | 12:17 PM
kcrumbley's Avatar
Arrow Just An Update ???
So Who Is Running Nitrogen In Their Tires Now?? Since It Is More Available And Known To The Industry??
Old Jun 23, 2006 | 12:14 PM
Swanny05TL's Avatar
I recently worked in specialty gas sales for Praxair & one of my customers was a Ferrari dealership. They got regular deliveries of nitrogen bottles for their service shop.
The benefit is real-but only for ultra performance situations. 99% of the public would never know the difference in their cars. Mostly a gimmick for the street folk.
Yes-the tire starts out with air, but you only have to purge it a few times to displace the air with nitrogen.
Old Jun 23, 2006 | 02:52 PM
MichaelBenz's Avatar
CTS-V Import Slayer
Last autocross I was at...the guys were manually overfilling their tires to begin with to lessen the tire roll-over....and I can tell you they were not using nitrogen! I ran mine at standard pressure and had NO problem at all...I think they just have cheap tires or something...
Old Jun 23, 2006 | 03:23 PM
BruceLandry's Avatar
Hmmmmm, we have a big cylinder of Nitrogen here at work!!! We use it to pressure test A/C equipment to check for leaks and we also run it through the system if we are doing any brazing (it doesn’t oxidize inside the pipe).
I'll have to give it a try but you MUST use a regulator as when full the cylinder is pressurized up to between 3-4000PSI. Kaboom if not careful…
Old Jun 23, 2006 | 03:32 PM
CTS-V Import Slayer
You'd have more fun with a big cylinder of NOS!
Old Jun 24, 2006 | 12:27 PM
Ka0tik's Avatar
if nitrogen molecules are bigger, than wouldnt they be heavier? if they are heavier (if there is actually a noticeable difference) wouldnt that result in decreased gas mileage
Old Jun 24, 2006 | 01:19 PM
Stevie B's Avatar
the stuff is great, I don't have it, but just found out that Costco will put it in your tires. I had it in my tires back in the lates 70's thru the mid 80's, and well worth the investment!!!
Old Jun 24, 2006 | 03:04 PM
triggle's Avatar
'04 6mt Pearl
Mike
I think many of us have driven cars that have tires that look brand new but are very slippery when it gets a little wet out. Even thought the tires look brand new, the rubber is no longer supple.
I am not suggesting that it is just O2 that causes this because it is also UV but IF you can delay the hardening and degradation of the rubber it may be worth the effort.
Old Jun 24, 2006 | 03:09 PM
CTS-V Import Slayer
HOW LONG DO YOUR TIRES LAST? You must drive SLOW to see that kind of longevity in tires that this happens! Could happen I guess?
SQAcuraTL04
21
Nov 11, 2008 07:04 PM
EXRock
Nov 28, 2007 11:18 AM
Trackruner228
Jul 18, 2007 10:02 PM
hondamore
Jul 14, 2005 06:20 PM
