Flat Tire - Patch or Plug?
Old Oct 10, 2005 | 09:37 AM
hcekc's Avatar
Which repair works best? I read one thread where Los Gatos Acura repaired a flat due to a nail with a patch and the patch failed because of the glue. I've been getting plugs in all my flats (from a Shell station) on various vehicles and they seem to last til end of the life of the tire.
Old Oct 10, 2005 | 09:43 AM
Ron A's Avatar
Administrator
You should never use plugs, especially in high performance tires. Plugs are usually applied without removing the tire from the rim, so the installer doesn't have the opportunity to inspect the inside of the tire for any damage.
If it is properly repaired, a patch should also last forever, but it has less chance of popping out.
Old Oct 10, 2005 | 12:28 PM
Jeffa1's Avatar
Oh, oh. I've taken my flats to Sears Auto and BigO and they've always used plugs.
Old Oct 10, 2005 | 12:37 PM
NJ Aegean 03's Avatar
Ron is right, patches are the "better" way to go... however, I've had all my flats on all my cars repaired by a tire shop using plugs and the plugs have outlasted the tires.
Old Oct 10, 2005 | 01:16 PM
Repecat's Avatar
Gratis dictum
Discount Tire repaired a flat (nail puncture) I had last week and they used a plug AND patch. Safest way to go, I think.
Old Oct 10, 2005 | 03:23 PM
hcekc's Avatar
Thanks for the input. It's hard to find a place that does patches in the Bay Area. I used to ask, but gave up when I couldn't find a place anymore. IMO, the only way the plug would fall off is if you run your tires bald.
Thanks again!
Old Oct 11, 2005 | 12:48 PM
ziemer's Avatar
TL Rookie
I just had mine plugged/patched about a week or so ago. Sears did it for me and they use a combination plug/patch. The best description I can think of is the rubber tees you see at golf driving ranges used on the mats.
(About a 2" diameter disc with a plug attached in the center.)
Sears guarantees it as long as the tire.
Old Oct 11, 2005 | 03:41 PM
1FasTL's Avatar
ABP Auditor
Plug-Patch Combi unit is the best and only way to go. The decent tire shops in town should have them. Insist on it.
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
PeterPort
Oct 14, 2015 06:19 AM
lland
Oct 4, 2015 04:47 PM
fallacy
Sep 4, 2015 10:15 AM
