Fit Discussion for the XXR-527 Folks (Going agressive, might fail HARD)
#161
Fearless DIY Guy
I am going to measure the distance from the center of the hubcap to the top of the fenderwell with the OEs, put the XXRs on, then compress the arm to rest equidistant equal to the former; this should give us a spot-on comparison, at least as close as we can get without the tires.
Plus I can see how the McGards look on there as well
#164
dont return them my friend - i will help you through all the bugs to make them fit perfect-
heres an example why not to worry
Same Car just change in suspension travel
#170
Fearless DIY Guy
I gotta PC 'em
Fit test tonight, dropped off at the PC show tomorrow
http://www.liquidpowdercoats.com/
#172
well i will be the first to post these on a TL i guess
18x8.75 +20 with 225/40/18
before pics with stern st1's 18x8 +48 with 15mm spacers.
now xxr 527
now i dont know where to go from here, leave them as is with fenders rolled or camber in and go a bit lower, it is a daily driver.
i also run summer tires so i dont really want a alignment or have to raise it everytime winter and summer hits.
now xxr 527
#182
Yea I could go lower Nd I'm gonna try tomorrow after work. Anyone know if you can use a spring compressor while the shock is on to chance pirchs on the mini shocks? I really don't want to disassemble the whole shock?
#194
they will fit just fine, ive had a tiny rub and im barely rolled. i didnt go lower tonight because i do have to take my whole damn suspension out to change the hieght on these koni yellows
