Dropping the Front...??
I have the A-Spec suspension on my 8 1/2 18" A-Spec rims.
After the suspension install, I cannot get over the lack of drop in the front.
Back looks great but the front did not have the same effect. Would like to drop the front 1" more.
Suspension gurus, What do you think of this:
1. Could I change just the springs on the front (replace the a-spec springs & keep the shocks)?
2. I would now need a front end camber kit right?
3. Would the a-spec shocks work with an aftermarket spring thus keeping the current feel of the a-spec suspension?
4. What springs will drop 1" below the current a-spec front end suspension?
I have changed just springs before and not the shocks on other cars (the last was a Mustang Cobra) and was extremely dissatisfied with the suspension afterwards..
Any ideas? Want to minimize my costs here. I know I could put TEIN's all around but want to see if I can manage with just doing the front and be happy..
I'm wondering how Acura gets away with zero camber adjustments yet they'll drop the stuff with A-Spec, but apparently very very little on the fronts.
Any, I repeat, any drop on the suspension throws off camber! You'll need a camber kit.
Acura says different about the camber kit. But that is a different subject.
gman, what you are proposing negates the advantage of the A-Spec: improvement in handling over the stock TL without significant loss of comfort. The drop on mine is 0.5", front and back, barely enough to notice--a plus for me.
If you want to drop the front further, you will need to use a different, complete--front and rear--spring (and, preferably, shock) set such as the Tein coilovers, or the Comptechs + Koni Yellows. My understanding is that it's better to use a complete, similar set. If someone else more in the know can correct me, please do.
professional TL driver
now, would it be good to have? i belive so. but dropping it less then an inch, 1/2 inch in the case of the aspec, the changes in camber will be minimal. anything more an inch and i would strongly recommend a camber kit
you could keep all four stuts and change springs and it wouldnt be so bad, but changing just the front and your looking for problems.
Team NightHawk VP
if you drop your car with comptechs, YOU DO NEED CAMBER KIT!!! like onager said, youll pretty much need a camber kit with any kind of springs besides the aspec drop, because i believe that the aspec is the only kit out there that drops .5"
Ahhhhh.....so this topic get discussed over here as well! I have the A-Spec suspension for my TSX; it is a significant improvement over stock. It doesn't drop the car much, but then it's not really designed to drop the car.
If you drop the car another 1" in the front, then you will have given up a good percentage of your suspension travel; close to 50% I'd guess. At that point, any spring you are using will have to be pretty stiff to keep from bottoming out. So there goes your factory ride. This is true for all cars-you can't be slammed and have a plush ride.
Koni Sport struts set to full soft and Comptech springs are the next step- a little lower, a little stiffer.
Don't change just the springs on the A-Spec strut-not only will you get a bouncy ride, but the strut will wear much faster.
dropping the front more than the back may affect weight distribution...
Also.. having say Comptechs in the front and Apec in the back, you're putting 2 diff suspension setups, i.e. different spring rates and that really messes the feel and handling of the car. You're betting off purchasing Teins, and dropping the front lower than the back. that would work.
9.5+10.5 22m=Hella Flush
That is the reason why I am going with H&R racing springs that will lower our TL 2inches front and 1.7 rear. Planning on ordering them soon.
I too have the A-Spec suspension and wouldn't mind having the front a bit lower or at least to have the gap in the front match the rear.
Since I'm happy with the ride quality and the handling I too was thinking about only changing the front spring to something aftermarket (ie. comptechs). However with further consideration and everyones comments on the issue, I may have to think twice about it first.
I just have to ask, are the stuts on the A-Spec suspension different than the non A-Spec, and if so, how? I know a lot of TLers are putting lowering springs using their non A-Spec struts so why not put aftermarket springs on the car using the A-Spec struts?
VTEC HoooA
Originally Posted by chusteveb
Also maybe someone can claify for me, is the A-Spec susension different for the 6MT vs. 5AT, if so how?
The stock suspension is different between the models though, more specifically the size of the front upper strut, and rear anti sway bar are both larger on the 6MT.
Originally Posted by Nodoze2004
No the suspension parts within the A-Spec kit are the same. The only difference between the 5AT and 6MT is the inclusion of high perf brake pads for the 5AT.
emailnatec
29
09-28-2018 04:27 PM
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
us285126
10-02-2015 02:03 PM
4drviper
09-23-2015 07:42 PM
