D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
Old 09-01-2014, 08:55 PM
  #2681
ct_ua6's Avatar
2005 6 Speed Navi
Wheel Make/Model: xxr 521
Wheel Size 18x10
Wheel Offset +20
If lowered: Not lowered
Already know I need spacers to clear my front brembos, but do I need my fenders rolled and pulled?
Old 09-02-2014, 06:01 AM
  #2682
Bswain321's Avatar
Questions on Wheels
Wheel Make/Model:varrstoen ES2
Wheel Size (**X**):F18x9.5 R18x10.5
Wheel Offset (+**):F+30 R+22
If lowered (amount): 1.5"
Old 09-02-2014, 11:08 PM
  #2683
3rd Gear
LetsGoAcura's Avatar
BMW Rims?
Sorry guys, new to this forum. I have a friend with an extra set of BMW style# 59475 rims. All BMWs are 5x120 lug patterns, and TL's are 5x114.3's. I'm not really that wheel savvy, so I need some help in getting them to fit on my car.
I found a set of spacer adapters: http://adaptitusa.com/browseproducts...l-Adapter.HTML
I'm not sure how offset and spacing will play into the fitment on my car. I also do know it's possible, as I've seen the TL-S's with the 7 series BMW rims on it (looks awesome).
Can someone please help me out? Thanks!
Old 09-03-2014, 12:49 AM
  #2684
sockr1's Avatar
Received 1,160 Likes on 909 Posts
there's some wheel shops that will modify the lug pattern slightly so that the bmw wheels will fit, they are pretty close already.
warning though...most big box stores will not touch your modified wheels if you try to get tires on them or do any rotations with big stores.
i got a set of avant gardes modified to our lug pattern from the bmw lugs, and no store would touch my wheels to put on tires. luckily they didn't clear the brembos even though they were guaranteed to clear, so the wheel company gave me full reimbursement and i got rid of that headache
LetsGoAcura (09-04-2014)
Old 09-03-2014, 12:48 PM
  #2685
3rd Gear
so basically, not worth it. I'm guessing this is a really cost-ineffective way to get aftermarket wheels on your car?
Old 09-04-2014, 10:43 AM
  #2686
3rd Gear
Originally Posted by stillhere153
Yes that is right... another thread to avoid excessive new threads
Please follow this format to get a quick and accurate reply
Questions on Wheels
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
Question on Brembo/Big Brake Clearance
Transmission (Manual or Auto):
Year/Trim (04-07, Base or Type S):
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
Questions on Tires
Tire Make/Model:
Width/Sidewall-Diameter (***/**-**):
Need a spacer?
For 5mm H&R/Eibach or Ichiba work
For 5mm or greater visit wheeladapter.com (custom widths available)
Extended Wheel Studs are always the best way to go
Wheel: STR 514
Offset: +25
Also looking to get 20 or 25mm spacers. How would this play into fitment?
Thanks guys
Old 09-04-2014, 02:28 PM
  #2687
Bswain321's Avatar
Questions on Wheels
Wheel Make/Model: varrstoen es6
Wheel Size (**X**):18x9.5f 18x10.5r
Wheel Offset (+**):+22 f/r
If lowered (amount):1.5
Old 09-06-2014, 08:09 PM
  #2688
5th Gear
UnderFunded's Avatar
08 TL base.
so i should have no problems running 8.5 all around with 245/35/19 with 1.5" drop and+33 offset? my first post on this forum im hoping its in the right place. cheers.
Old 09-09-2014, 09:20 PM
  #2689
6th Gear
JTL21's Avatar
Noob Alert ! haha
Quick Question: Its Time I Upgrade The Stock 17"inch Tires and Rims To 19"inch Tires And 19x8.75 Rims
Which Kind Of Tire Width Will Go Correctly 245 or 255 tires?
Would I Need To Upgrade Suspension To Prevent Rubbing Agaisnt The Fenders Or Suspension, Since Stock Suspension Is Made For 17"inch Tire (Well From What Ive Read)
Old 09-12-2014, 03:25 PM
  #2690
vpasla1's Avatar
2G TL-S on 2004 TL Base
Questions on Wheels
Wheel Make/Model: 2003 Acura TL Type-S
Wheel Size (**X**): 17 x 6.5
Wheel Offset (+**): unsure
If lowered (amount): n/a
Vehicle - 2004 Acura TL 5AT Base (Completely Stock)
Thanks in advanced!
Old 09-12-2014, 06:29 PM
  #2691
jthiessens's Avatar
Have an 07 type s and looking at a set of Ron Jon legacy 7's 18x8 off set +48, I know Aspecs are close to these specs, can I run these without spacers and clear brembo's? I'm dropped about 1inch.
Thanks in advance
Old 10-15-2014, 02:58 PM
  #2692
Motomano's Avatar
Question on Tire size
2007 RDX Base no mods.
Wheel size: 18X7.5 stock
Current tire 235/55R18
Would like to know if there will be any rubbing issue if I go for 245/60R18 on the same wheels.
Thanks.
Old 10-30-2014, 11:02 AM
  #2693
I'm lost..
ray-ban's Avatar
07 Type S
STR 607 Rims
19x8.5
19x10
5x114.3
+30 offset
I'm running on Tein Htechs (less than an inch drop all around)
19x8 5 30 19x10 STR 607 5x114 3 GUN Metal RIM FIT Scion TC XB Acura RSX TSX TL | eBay
I'm assuming no issues with these wheels? Rubbing? Clearing Brembos? Thanks guys
Old 10-31-2014, 12:12 AM
  #2694
I'm lost..
ray-ban's Avatar
Also forgot to ask what size tires I should pair this with?
Old 11-01-2014, 08:43 AM
  #2695
CLtotheTL32's Avatar
Received 9,528 Likes on 6,183 Posts
Wheel: STR 514
Offset: +25
Thanks guys
Those wheels are 2" wider and 20mm more aggressive than stock wheels; don't buy spacers.
Originally Posted by Bswain321
Questions on Wheels
They'll fit but you'll need to run a narrow tire, roll the rear fenders, and run some negative camber.
Roll your rear fenders and you'll be fine.
Originally Posted by JTL21
Noob Alert ! haha
245/35/19 with 19x8.75 wheels will be fine. You can leave the stock suspension on there but you'll have tons of wheel gap.
Thanks in advance
You'll most likely need a 3mm spacer to clear the Brembos since the A-Specs are +45.
Originally Posted by ray-ban
07 Type S
STR 607 Rims
19x8.5
19x10
5x114.3
+30 offset
The fronts will be fine but the rears are aggressive. You'll need to roll the rear fenders, run a narrow tire, and dial in some negative camber to clear.
I would buy 235/40/18 for all four wheels, that way the rears get a slight stretch. Depending on your alignment specs, you could run a 225 up front to dial out some of the negative camber. Do you have adjustable ball joints or control arms up front? What about adjustable camber arms for the rear?
For the link you posted, the hub bore is the wrong size; TL is 64.1mm. You could buy them, but then you'll need hubcentric rings to ensure they mount properly and don't create any vibrations.
Old 11-01-2014, 02:10 PM
  #2696
I'm lost..
ray-ban's Avatar
Thanks for the reply bud! I have the hub rings already and figured I'd probably have to roll the rears. As for adjustable ball joints or control arms, it's all stock so I'm not sure what the answer to that is. I don't imagine camber kits are too expensive are they? Someone told! With the drop the camber won't be too much an issue but hard to tell until I get the tires. Thanks again
Old 11-04-2014, 01:31 PM
  #2697
mmcc73's Avatar
If this is better posted elsewhere, please let me know.
2005 TL, Manual transmission with Nav system, stock everything, not lowered.
I'm not asking about a specific wheel, rather I'm looking for recommendations. If this would be better posted elsewhere, please let me know.
Winter is coming. With it come potholes. I'd like to mount 16" wheels and higher profile tires that will better absorb the shock without knocking the wheels out of round.
I've seen some posts suggesting that the brakes on an 05' with a manual transmission won't support smaller wheels. Is that correct?
Are there any smaller wheels that would work without a tremendous amount of hassle?
Old 11-18-2014, 01:44 AM
  #2698
7th Gear
BoostJunkie21's Avatar
07 TL base 6mt
Wheels : Forgestar F14F
18x10 (reverse lip)
+w/e I need
5x114.3
I have the option to go -30 to +75 on the offsets.
need to know what offset I need to clear Stoptechs. Doing a major winter overhaul and would like to know wheel specs that will clear stoptechs. I would like 18x10 wheels but will go down to 18x9 if needed. Thank you in advanced for an answer.
Old 11-20-2014, 12:18 PM
  #2699
Modassir's Avatar
Transmission (Manual or Auto): Manual
Year/Trim (04-07, Base or Type S): 05 Base
Wheel Make/Model: VarrStoen ES6
Wheel Size (**X**): 18x9.5
Wheel Offset (+**): +13
If lowered (amount): N/A
Just wondering if anyone has an idea if these would clear our factory Brembo brake calipers. I had 17" MB Battles 9.5" wide and +15 offset and they fit without spacers. I'm not worried about poke because I'm having fender work done, really just wondering if the wheel will clear the brakes. Thanks.
Old 11-21-2014, 10:40 AM
  #2700
Reaper76's Avatar
will these wheels and tire size work on my tl
Questions on Wheels
Wheel Make/Model:SSR GTV02
Wheel Offset (+**):+35mm
If lowered (amount):tein stechs so about 2 inches I think
Transmission (Manual or Auto):Auto
Year/Trim (04-07, Base or Type S):Base
Wheel Size (**X**):18X9.5
If lowered (amount):Tein Stechs-stock shocks
Questions on Tires
Tire Make/Model:
Width/Sidewall-Diameter (***/**-**):245/40-18
If lowered (amount):2 inches ish
Need a spacer?
I am wanting to know if the wheel tire combo above will work on my 04 base tl with no fender mods.Thanks
Old 11-21-2014, 10:47 AM
  #2701
Reaper76's Avatar
Originally Posted by Reaper76
Questions on Wheels
Questions on Tires
Tire Make/Model:
Need a spacer?
sorry for the repost but this is the size im looking for 18x9 +35mm offset with 245/40-18's will thye work with my set up and fender mods? Thanks
Old 11-26-2014, 09:01 PM
  #2702
7th Gear
John Brennan's Avatar
Question from Newbie
Manual Transmission
2006 Base
Wheel Make/Model: This is what I am looking for
Wheel Size: 17x8
Wheel Offset: Stock
Not lowered
Hi
I am new to the forum as well as forums in general. I copied & pasted the questions and filled them out, not sure how the formatting will come out.
I am looking to find out which Honda family vehicles came with rims that will fit so that I can scavenge the junk yards. I would prefer steel but alloy will work.
I am trying to help out a friend. I found her snow tires and am now looking for rims that will work/fit so she can have both sets mounted and just swap out when she needs to. She just graduated from nursing school and has huge student loans so I am trying to do this on the cheap.
The next thing is her car gets inspected in June. I know there will be a warning from the TPMS system but will the whole thing wig out if we skip the sensors in the rims and it stays on from November to April?
Thanks, John.
Old 11-27-2014, 10:01 AM
  #2703
7th Gear
Hi
I can't figure out the PM system. I got an e-mail from AcuraZine that glan2014glan had sent me a PM but I had reached my quota. I think I cleaned it out but was not able to send a PM to glan2014glan. So would you please send an e-mail to GM_EA@yahoo.com or try re-sending the PM?
Thanks, John.
Old 01-12-2015, 10:46 AM
  #2704
dapunisher0855's Avatar
What about an 05 infiniti 19 inch wheel off of a G35? I know the bolt pattern is the same but was wondering since my car is a 05 TL 6-speed.
Old 01-21-2015, 11:55 PM
  #2705
ua6jdm's Avatar
05 acura tl base 6mt
Wheel Make/Model:MB Battle
Wheel Offset (+**):+38mm
If lowered (amount):tein s techs 1.5?
Would this setup rub and will i need spacers? what tire measurements would go well with is? thanks
Old 02-01-2015, 11:14 PM
  #2706
9th Gear
aptwo's Avatar
07 TL-S
Wheel Make/Model: Varrstoen ES4
Wheel Size: 19x8.5F / x10.5R
Wheel Offset: +32F / +43R
Tire Size: 235/35/19F / 255/35/19R
If lowered (amount): Tein S-techs (~1.5")
Would like to know if this will fit without a fender roll. What about 225 and 245? Thanks.
Old 02-14-2015, 01:53 PM
  #2707
6th Gear
Astiris's Avatar
Xxr 530
Hello Acurazine!
Questions on Wheels
Wheel Make/Model: XXR 530 - Chromium Black
Wheel Size: Front: 18" X 8.75" Rear: 18" X 9.75"
Wheel Offset: Front: +33mm or+20mm Rear: +20mm
If lowered: .5" roughly (Koni Yellow - Type S stock spring)
I am going for 18" all around, but want a bit of a stagger from the from to the rear. Would like the rear to appear larger.
If anyone has any insight on the tire sizes I can pull off, it would be much appreciated.
Tire possibilities?:
Front: 235/35/18 or 245/35/18
Rear: 245/35/18 or 255/35/18
Thank you guys! Let me know what you think!
Old 02-15-2015, 01:54 PM
  #2708
7th Gear
What year, model and transmission do you have?
Old 02-15-2015, 01:56 PM
  #2709
7th Gear
Looking for wheels
What wheels will fit an '06 TL with a 6-speed?
Old 02-15-2015, 01:58 PM
  #2710
7th Gear
Meeting the requirements
This is post #5 so that I can now go to the black market and look for wheel.
Thanks, John.
Old 02-16-2015, 05:20 PM
  #2711
6th Gear
Astiris's Avatar
2008 TL Type-S 6MT
Old 02-17-2015, 11:52 AM
  #2712
7th Gear
Hi Astris,
I can't figure out the PM function, I put the old in Old School. When you get a chance please give me a call at 603-727-8159. A friend has an '06 TL with a 6 speed and is looking for a set of wheels.
Thanks, John.
Old 02-17-2015, 11:53 AM
  #2713
7th Gear
OH, if e-mail works better mine is GM_EA@yahoo.com
Thanks, John.
Old 02-18-2015, 05:02 AM
  #2714
dpFRESH's Avatar
Transmission: Manual
Year/Trim 05 Base (Dynamic)
Wheel Make/Model: BBS RGR
Wheel Size: 19x8
Wheel Offset: +42
If lowered (amount):N/A
Thank you!
Old 02-25-2015, 09:49 AM
  #2715
nobodyphil's Avatar
Transmission: Auto
Year/Trim 07 Base
Wheel Make/Model: Enkei RPF1
Wheel Size: 17X9
Wheel Offset: +45
If lowered (amount): H&R Race springs (around 2 inches)
The tires i am thinking about using are 215/45's
Thank you
Old 02-28-2015, 12:31 PM
  #2716
Janagan_ua7's Avatar
Year/Trim 07 Type s
Wheel Make/Model: Work VS-XX
Wheel Size: 18x10 +21 R-Disk (F) and 18x10 +25 A-Disk (R)
If lowered (amount): BC coilovers, bought but not installed yet, planning to go low
The tires i am thinking about using are 225/40/18
Thank you
Old 02-28-2015, 02:55 PM
  #2717
Moved to the LOU
twigglius's Avatar
Year/Trim 07 Type s
Thank you
This will require fender work + a large amount of - camber. You will probably also need to run 215's. If done correctly it will look really good.
Old 02-28-2015, 02:57 PM
  #2718
Moved to the LOU
twigglius's Avatar
Originally Posted by nobodyphil
Transmission: Auto
Year/Trim 07 Base
Wheel Size: 17X9
Wheel Offset: +45
Thank you
You could run 245's with this setup and still not rub. It's not aggressive at all.
Old 03-17-2015, 12:16 PM
  #2719
JD TL-S's Avatar
I had the wheels I have now on an 07 WDP TL Type-S with TEIN SA Coilovers lowered about 1.5 inches. Wheels are 19x8.5" +35 offset and did not rub. Also did not need added parts. Just got it aliegned and all was good with tire wear.
19"x8.5" Axis Hiro +35 wheels. 245/35/19" Perfect IMO
TEIN SA Lowered 1.5" F&R
No needed parts for aliegnment.
In this Avatar I have A-Spec coilovers- ( Want TEIN SA- No $$$ )
Maybe TEIN S-tech springs soon ???
Old 03-21-2015, 12:58 AM
  #2720
5th Gear
Juan Lepe's Avatar
Question
04 TL base
Jnc wheels 17x 8.5 with a +30 offset
Will these fit properly or would need spacers not sure how the offset works thanks.
Quick Reply: D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
