Concern on Wheels?
Concern on Wheels?
I have the 07 TypeS. i would like to put some 19x9.5 all around but would like to know if i'm gonna need to do some work for them to fit right. i would like to drop it on tein s tech which i believe its a 1.5 inch drop unless its to much work
you'll need some pretty gnarly fender work/neg camber to fit those wheels on a 3G TL.
there is a guy in the black market selling that same set right now, PM him and see what he had to do to make them fit on his.
^ yea too much work imo for your first set up .... + 12 offset up front you would have to run like -3 camber and pull fenders while running a 225/35 max tire size
go for a more conservative offset like +30 up front
sp if i were to do 19x9.5 +30 it would be fine. but will it clear the caliper. Right now im running 18x8 tenzo type m not sure of the offset with 235/40 but i feel that the wheels look small and there too much space between the tire the fender
^ i am running a 19"x9.5" +28 offset up front on my car and it clears the brembo caliper but obviously a different rim style but i would think they should clear ok with what you have noted.... you will be flush up front and need to run a 225/35/19 tire....
whats your plans for out back what size rim??
and you didn't need to add spacers or roll the fenders. Do you have a pictures on how the set up look from different angles i just want to do 9.5 0r 9 all around but for it to clear the calipers and give it a wider look. also hopefully have a small lip on the wheels. i just like that style. but obviously the original ones run some good cash
i'm running 19x9 +25 FRONT and 19x9.5 +25 REAR on 225/35/19 tires. fenders rolled. no spacers. just to give you an idea.
i know you guys are probably tired of seeing those same pictures in similar threads, but i'm just trying to help out OP so he can get an idea of how things look when they're all said n done.
