18 x 7.5-42 offset wheel
Old 04-29-2012, 08:13 PM
Westside_TL's Avatar
will rims with 18X7.5 10H 42OFFSET fit on a 07 tl acura?
Old 04-29-2012, 09:35 PM
MATT
06cmv6's Avatar
Yes unless the car has the brembo brakes than they will not without spacers
Old 04-29-2012, 09:52 PM
Jesstzn's Avatar
Stock TL is an 8" rim ... whats the bolt pattern?
Old 04-30-2012, 06:58 AM
its 5 bolt think brakes n all r stock... 18" rim
Old 04-30-2012, 08:33 AM
Jesstzn's Avatar
There is lots of 5 bolt patterns .. is it 5 x 114.3?
Old 05-01-2012, 12:53 PM
Bolt Pattern: 5X100 5X114.3 Rim Diameter: 18
Old 05-01-2012, 04:03 PM
Old 05-03-2012, 06:55 PM
anyoneknow if this will fit??
Old 05-03-2012, 08:29 PM
Turbonut's Avatar
Don't know why one would want a smaller wheel width, but what is the hub bore size? Seems like it's a 10 hole wheel and will fit a 5x100 and/or a 5x114.3 bolt pattern, so as far as the bolt pattern and +42 offset it will fit. Inner part of wheel will be out 9mm more than stock and outside will be in 3mm. With the 7.5" width neither a 235/40 nor a 245/40 is recommended.
Stick with a 8" min width.
Westside_TL (05-04-2012)
Old 05-04-2012, 07:15 AM
thanks thas what i needed to know!!!! glad u answered before i orded it would of looked dumb
Old 05-04-2012, 08:52 AM
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
I second an 8" rim or larger, going bigger could cause rubbing problems though, especially if you're lowered. I ordered 18x8.5 +30.
Old 05-05-2012, 11:04 AM
so whas the best site for rims??
Old 05-05-2012, 11:10 AM
it all comes down to preference but generally you don't want to go smaller than stock. 18 or 19" rims are great for the TL. As for width, I wouldn't go any wider than 9.5, and that is being generous.
02-25-2020 09:57 AM
KB1_EJ6
08-28-2016 08:25 AM
BreezyTL
07-26-2016 12:52 PM
nuldabz
09-03-2015 05:49 PM
bailey24
08-31-2015 05:38 PM
Quick Reply: 18 x 7.5-42 offset wheel
