18 x 7.5-42 offset wheel
will rims with 18X7.5 10H 42OFFSET fit on a 07 tl acura?
Yes unless the car has the brembo brakes than they will not without spacers
Stock TL is an 8" rim ... whats the bolt pattern?
Originally Posted by Jesstzn
(Post 13739976)
Originally Posted by Westside_TL
(Post 13740469)
its 5 bolt think brakes n all r stock... 18" rim
Bolt Pattern: 5X100 5X114.3 Rim Diameter: 18
(Post 13740611)
There is lots of 5 bolt patterns .. is it 5 x 114.3?
Bolt Pattern: 5X100 5X114.3 Rim Diameter: 18 |
anyoneknow if this will fit??
Don't know why one would want a smaller wheel width, but what is the hub bore size? Seems like it's a 10 hole wheel and will fit a 5x100 and/or a 5x114.3 bolt pattern, so as far as the bolt pattern and +42 offset it will fit. Inner part of wheel will be out 9mm more than stock and outside will be in 3mm. With the 7.5" width neither a 235/40 nor a 245/40 is recommended.
Stick with a 8" min width. |
Originally Posted by Turbonut
(Post 13752016)
I second an 8" rim or larger, going bigger could cause rubbing problems though, especially if you're lowered. I ordered 18x8.5 +30.
so whas the best site for rims??
:shrug: it all comes down to preference but generally you don't want to go smaller than stock. 18 or 19" rims are great for the TL. As for width, I wouldn't go any wider than 9.5, and that is being generous.
