18 x 7.5-42 offset wheel
Don't know why one would want a smaller wheel width, but what is the hub bore size? Seems like it's a 10 hole wheel and will fit a 5x100 and/or a 5x114.3 bolt pattern, so as far as the bolt pattern and +42 offset it will fit. Inner part of wheel will be out 9mm more than stock and outside will be in 3mm. With the 7.5" width neither a 235/40 nor a 245/40 is recommended.
Stick with a 8" min width.
Westside_TL (05-04-2012)
Received 3,824 Likes
I second an 8" rim or larger, going bigger could cause rubbing problems though, especially if you're lowered. I ordered 18x8.5 +30.
it all comes down to preference but generally you don't want to go smaller than stock. 18 or 19" rims are great for the TL. As for width, I wouldn't go any wider than 9.5, and that is being generous.
nuldabz
09-03-2015 05:49 PM
