'05 TL with G37 Wheels going crazy
since i got the g37 wheels in my car ive been getting a really bad vibration on the car when i do 60mph i heard it was because the hub centric rings and i got a set that fit my tl and the wheels so i thought the vibration was going to be over but it wasnt so i got the wheels balanced and aligned and still the vibration was there then someone told me it was the lock nuts so i got a new set that fit the rims perfect but shit the vibration still there then a i got a new set of tires and the vibration still there i dont know what to do anymore this vibration is getting me crazy many ppl say is the wheels but im not sure if there is a way to make my car runs perfect the g37 wheels. any one knows whats going on?
Balance the wheels on a Hunter Road force then turn it 180 degrees and check, if perfect great, but if off, either the center bore is compromised or the machine is out of calibration. They can always use the lug adapter to do the balance rather than the cone for the center, then you’d know it was centered.
http://www.gsp9700.com/search/findgsp9700.cfm
Move 1 front wheel to the back then drive it to see if the vibration changes , if not .. move the other to the back. This way if its a wheel/tire you will be able to isolate which one.
If the vibration is still in the stereeing wheel then its something else.
have you recently swapped out you axles? if not i would check them and if you have or need some axles, ONLY buy the OEM axles....aftermarket axles arent balanced.....my recent problem so thought i would share.
what tire size and how many psi are you running on each?
check for uneven tire ware, inner/outer. I had exact same problem. Check out my thread : https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/tire-sidewall-defect-858242/
Your problem is the G37 wheels are lug centric. Your problem would be solved by using the stock g37 lugs, but unfortunately you cannot because nissan uses a 12x1.25 stud and honda uses a 12x1.50. I have a set of these wheels lying around as well and tried with little luck to get the vibration gone. The closest nut I found was a Mitsubishi spec, yet it is still a bit shy of what you need. I gave up on my attempt, but please update if you come up with a creative way to use these vibration free.
Here is some information that I learn the hard way. (Rooki mistake)
I also have G37 wheels and the seller game some lug nuts with the wheels.
I have added hub centric spacer (8mm to clear Brembo calipers) and hub centric rings and all good.
So 3 weeks ago I decided to get some newer lug nuts for the car and I order some OEM G37 (big mistake). The thread on the Acura TL is M12x1.50 and the thread on G37 is M12x1.25 and they use Mag shape lug nuts.
Now I have to replace all the wheel studs on my car. =(
I did some research and I look back into the purchase of the wheels and the seller mention that he had Toyota Camry lug nuts on his TL and that does were the lug nuts that he had given me at the purchase.
I hope this information helps you out.
Best of luck.
V/r
Melvin Hdz
Best of luck.
V/r
Melvin Hdz
Chapter Leader (San Antonio)
I use to have them and Discount Tire provided the lugs and they worked perfect. I have them somewhere if someone wants them.
Once you fix the hub-ring... you shouldn't have a problem whatsoever.
I ran mine for months without vibrations until I hit a big pothole which ended up causing a bent.
marcelft
Jul 10, 2018 06:17 PM
