Won't rev higher than 4500-5000 RPM!
Hey Acurazine,
It appears to me that when driving my Acura TL 2004 3.2 base. I can never get it to rev this high like in this videos. This video shows 0-60 for the TL. I've tried putting it into manual mode and holding it high in second gear but it seems like the car doesn't wanna go higher than 5000 RPM. Yet this video the person has it rev so easily up to the redline and 6000 rpm range. What is going on with my car?????????
Here's the video btw:
http://m.youtube.com/watch?v=1msawteaBvg
What the heck is going on? No matter how hard I floor my gas pedal for my car on normal drive, it stays in the 4500-5000 rpm range and never past it!???
Anyone help?
Anyone help?
I can also easily rev above 6500rpm. Has it been like that for a long time? have you see a gradual loss in power? More details please.
Could be transmission, could be clogged catalytic converter, could be a lot of other things as well but not enough info to close in.
My car drives fine and the speed is there, ive never noticed this wasn't normal until I saw videos of 0-60 NOT just from this car but from other cars and their RPMs all rev up to the red line. My car has no codes. What could this be??
I know for a fact that if I floor my car too much I get a rotten egg smell. But I'm not sure if that's a cause. I really want to fix this problem. But car feels and sounds like it works so hard just to get up to 5000 RPM. What should I do?
My mechanic test drove my car today and said the transmission shifts fine. It's just odd how I can never get up to the red line. I just can't, it doesn't seem to go past 5000 rpm.
If that wasn't enough proof, you can jack up the cat and tap on the cat with a rubber mallet, there is a good chance you'll hear a rattle.
The fact that your CEL didnt come on (and stay on) before is a mystery to me, but don't wait until it does to change it...it might be too late. Best case scenario you'll be stranded on the side of the road, worse case, you'll blow your exhaust gasket, WORST case, you wont even realize that exhaust fumes are leaking in the cabin, you'll intoxicate yourself and anybody in the car, pass out and suffer permanent brain damage, if not death.
You can also test the cat using an IR heat gun. The outlet side of the cat should be considerably hotter than the inlet side if it working the way it is supposed too.
That is how I confirmed mine was bad, not only was the outlet side not hotter, it was cooler.
https://www.youtube.com/watch?v=8f2P5yJFQKw
Easy now, a clogged cat would never cause this. But it does remind me of a Simpsons clip. "Don't kid yourself, if a converter ever got the chance... it would kill you and everyone you care about"....
This type of news is rare, but it does happen. There are many documented cases, especially during natural disasters in colder weather where stranded people go in their car and keep it rolling to keep warm. Out of a few hundred, if not thousand people, it only takes one clogged cat and a hole somewhere before the cat and the recipe for disaster is cooking up. Exhaust fumes are VERY dangerous. You can't see them, you can't smell them, and they kill in minutes, if not, they can permanently damage a braing in 2 minutes of exposure to a high concentration.
Quote of Wiki
The NFPA standard is not necessarily enforced by law. As of April 2006, the U.S. state of Massachusetts require detectors to be present in all residences with potential CO sources, regardless of building age and whether they are owner-occupied or rented.[91] This is enforced by municipal inspectors, and was inspired by the death of 7-year-old Nicole Garofalo in 2005 due to snow blocking a home heating vent.[92] Other jurisdictions may have no requirement or only mandate detectors for new construction or at time of sale.
Despite similar deaths in vehicles with clogged exhaust pipes (for example in the Northeastern United States blizzard of 1978 and February 2013 nor'easter) and the commercial availability of the equipment, there is no legal requirement for automotive CO detectors.
Right now my car still can't rev higher than 4500 rpm even when I floor it
You're the one that needs convincing. I remember seeing it on the news and it marked me because it was so close to home. Go look yourself.
There are tons of cases of accidental deaths due to blocked exhausts by snow, mud, or objects. When a cat clogs up, its the same problem, just closer to the engine.
I need help finding a case where someone died because of a clogged cat. Fully blocked exhaust system with mud, snow, or banana in the tailpipe running in the same spot for a long time....sure that has killed a few people.
Oh great... not the bunny. Will a car run with a 100% completely clogged converter? 100% back pressure? Maybe for a minute... not long enough to exfoliate the operator and their entire family. Pre cat exhaust might smell a little too. Most likely the "clogged cat" the op has is only partly blocked as he is still reaching decent RPMs. Telling him his issue is potentially fatal is an extreme stretch. As proven from the lack of evidence provided that it happens all the time.
Will a car run with a completely blocked tailpipe?
I used entirely when I should have used almost completely. No use being pedantic, English is a second language to me.
Do you usually wake up because of a smell? Researchers say olfactory stimuli will not wake up you. Whether it's straight CO2 or propane you won't wake up because of that...
Do I believe the op is going to asphyxiate? No. I think it's far fetched to think it will lead to that but it's not impossible either.
Not sure what's your issue with me.
Again, I guess we can go by the mentality of "anything is possible". The odds of the op dying tonight because of a partially clogged cat are far less than winning the lottery 5 times in a row while being struck by lighting. If we should suggest something for the op to worry about that actually might happen....When is the last time you checked the tightness of the spark plugs?
No issue with you, I like ya, you give great advice on the site and are a fellow Canadian. ( although I live in Kansas now )
OP has mentioned having this problem for a long time, chances are, hes close or on his way to a clogged cat. I was exaggerating when i said death awaits him is he doesnt act, but i wanted to be a little funny by giving his the best case, and worst possible case scenario.
The red text denoting a hint of sarcasm maybe should have been used.All in all, the OP likely has a catalytic converter problem.
DerrickW
Nov 15, 2015 05:52 PM
