Windshield Washer Problem
Old Jan 16, 2011 | 08:11 AM
VQPower37's Avatar
Question Windshield Washer Problem
Hi Guys,
So I am having a problem with my windshield washer fluid. At first I thought because it is very cold outside the fluid is freezing which is causing it not to work. However, I couldnt here the pump as I used to be able to when I pulled the stock back. I began to think it had something to do with the fuse being blown. I did a little searching on here and it seems to be a common problem that the wiper fluid pump fuse blowing on TLs however my rear view mirror was working as was my tilt function so I knew it wasnt the fuse. Randomly though when I pull the stock back the fluid comes onto the windshield now.
So I am not sure what the problem could be, has anyone had issues like this? Or direct me in a way I can trouble shoot some more?
Thanks for an insight anyone can provide.
Old Jan 16, 2011 | 02:32 PM
dzionny_dzionassi's Avatar
i had same problem, was looking for bad fuses, because i didnt hear pump working. Didint find any bad fuses. I though that fluid frozed, but that was not the problem. Then what i did ,is just press and hold window whasher switch from minute to two minutes and it started to work again, never had same problem.
Old Jan 16, 2011 | 05:36 PM
VQPower37's Avatar
Hmm interesting ... i will try that out next time im in the car, its such a strange problem because nothing makes sense lol.
Thanks for the reply
Old Jan 16, 2011 | 05:45 PM
let me know if it will work for you.
Old Jan 16, 2011 | 06:18 PM
friesm2000's Avatar
B A N N E D
Originally Posted by VQPower37
Hi Guys,
maybe it just needs a new stalk , because the contacts inside the stalk have gone bad (or the wires have been pinched inside, causing a short and the fuse to blow) just maybe....
Old Jan 17, 2011 | 07:33 AM
VQPower37's Avatar
i was thinking about that too, but everything else functions properly from the stock such as the windshield wipers so im still skeptical about that
Old Jan 17, 2011 | 02:21 PM
friesm2000's Avatar
B A N N E D
all it takes is one wire to be cut though (which just so happens to be for the washer function)
Old Jan 19, 2011 | 06:46 AM
VQPower37's Avatar
Update on this ... I held the stock back for two mins and it started working, and has been good since, so i hope this resolved the issue
Old Jan 19, 2011 | 01:00 PM
friesm2000's Avatar
B A N N E D
WOW :shakehead
Old Jan 19, 2011 | 05:55 PM
it had been 2 months since it happend to me, no problems after that. i guess it is common problem for tl.
Old Jan 7, 2014 | 09:23 PM
namisiz's Avatar
amazing
It works for me, too. At first, I don't believe that. But, I have a same situation as "dzionny" (fuse is OK. I don't hear pump sound). There is nothing to loose and I just tried it. IT WORKS. Thank you.
Old Jan 30, 2014 | 05:46 PM
egibree's Avatar
having the same issue right now maybe ill try the holding of the stock ill post shortly
Old Jan 7, 2015 | 09:43 PM
Goldwinghai's Avatar
6th Gear
I am having the same problem, will try this tomorrow, hope this will solve the problem. Thank you for the tip.
Old Jan 13, 2015 | 08:52 PM
6th Gear
I followed the suggestions from another post on the same washer fluid problem and replaced the burned 7.5A fuse with a 10A fuse in the fuse slot #20, and it worked.
Old Apr 11, 2026 | 09:39 AM
nanxun's Avatar
DEFINITELY do this first!!
Thanks for this old thread, started 15+ years ago and on which the last post was more than 11 years ago.
Had this very same problem--wipers working, but no sound of the washer pump working--on my 3G (2007, UA7) TL.
After reading this thread, went out and started the car. Held the washer stalk back and after 90 seconds, the sprayer/pump started working. Easy as that!
No need to tear apart the right-front wheel well or even to check the in-cabin or under-hood fuses/electrical system. This is by far the EASIEST DIY fix-it I've ever done.
that it solves the problem for good (as reported by others above).
Thx again!
narnia
Feb 24, 2024 05:04 PM
pyckuu23
Oct 12, 2016 07:53 PM
bminkoff
1/2G MDX (2001-2013)
Jul 8, 2015 03:52 PM
direwolf2001
Feb 3, 2015 07:57 PM
PNJBi
1G TSX Problems & Fixes
Jan 5, 2009 11:36 AM
