Window roll up fix-please help!!!
Old Apr 26, 2013 | 04:47 PM
Kwang05tl's Avatar
8th Gear
I have searched and searched no posts about this... I hooked up my hm20 window roll up module from kp technologies and it starts to roll up then stops when i hit lock twice... any ideas ????
Old Apr 26, 2013 | 05:02 PM
hofiveo's Avatar
https://acurazine.com/forums/3g-tl-problems-fixes-114/drivers-auto-window-wont-go-up-down-866067/
Post #5 has the instructions
Old Apr 26, 2013 | 05:04 PM
hofiveo's Avatar
Better yet.
Just in case you need to do the reset, here is the procedure from shop manual:
Page 22-224 It is a pretty lengthy process.
1. Turn Ign switch on
2. Move the driver's(passenger's) window all the way down by using the driver's(passenger's)window DOWN switch.
3. Open the driver's(passenger's) door.
NOTE: Steps 4-7 MUST be done within 5 seconds of each other.
4. Turn the ingnition switch OFF.
5. Push and hold the driver's(passenger's) window DOWN switch.
6. Turn the ignition switch ON.
7. Release the driver's(passenger's) window DOWN switch.
8. Repeat steps 4-7 three more times
9. Wait one second.
10. Confirm that AUTO UP and AUTO DOWN do NOT work. If AUTO UP and DOWN work, go back to step 1.
11. Move the driver's(passenger's) window all the way down by using the driver's(passenger's) window DOWN switch.
12. Pull up and hold the driver's(passenger's) window UP switch until the window reaches the fully closed position, then continue to hold the switch for 1 second.
13. Confirm that the power window control unit is reset by using the driver's(passenger's) window AUTO UP and AUTO DOWN function.
If the window still does not work in AUTO, repeat the procedure several times, paying close attention to the 5 second time limit between steps. If it still does not work, go to B-Can System Diagnosis Test Mode A(see page 22-108)
Old May 1, 2013 | 09:53 AM
thegbu's Avatar
5th Gear
quick try - will reset process work where passenger window only goes up half way. then returns down? had this condition start recently...thanks
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
