Window Rattle
Window Rattle
From day one the driver side window makes noise. Roll it down and it's gone, dealer has replaced seal but the noise continues. Problem is intermittent but rattles at anytime are a bother........anyone have the same problem and if so what's the fix
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
Took it to dealer: "I hear nothing." That what dealer said, but I do hear it when I drive with closed windows and music is off.
I already paid 65$ to take whole door out and still no result.
Rattles are still there. So I just turn music on and set it as loaud as possible...
Remember Acura TL is not luxury car. It is built in USA = poor quaility.
TL 2012 SH-AWD TECH/UMBER
I had this issue on my 2003 accord, they replace the seal, ok for 1 or two months and rattle come back.
On my Tl it happens but more often with the seal of sunroof.
Resident auto maniac
Mine has the same problem but on both doors... i just have to get some time together and install some dynamat extreme. That should fix any rattling
Originally Posted by massr1
i fixed mine on my own, theres a thread on it that has pics on how to do it. im to lazy too look for it
https://acurazine.com/forums/car-parts-sale-361/%2A%2Amsd-window-switch%2A%2A-126626/
^ that ones good, but not the one i was talking about. you basically take apart the plastic door trim around the window and insert some felt. i used some thick foam tape and it worked.
https://acurazine.com/forums/acurazine-clubs-meets-15/belated-photos-la-meet-84527/
Dr. Feelgood
Originally Posted by SilverStoneTTL
i have a rattle with the window glass itself too, seems to be the cause of the fact that the window has a little room to shake
The second noise was the window glass vibration itself as SilverStoneTTL had mentioned. On the upper edge of the door, there is a plastic/ rubbler molding piece that the edge of the window will hit to seal the glass when the window is rolled up. If you use a flat head screw driver, you can pry this out enough to stick some felt behind it to make it bulge out slightly. When the window is rolled up, it will give a tight fit/ contact with the rubber molding.
Dr. Feelgood
Here are the pictures.
I used the fuzzy side of the velcro strip
pull back the rubber molding
stick the velcro on the edge of the rubber lining
For the rattle that seemed to have come from the dash around the A pillar area. I stuffed a thin piece of the same velcro in between the gap.
Let me know if this resolves anyone's rattle issues.
![](http://img222.imageshack.us/img222/7784/grill0429sb.jpg)
![](http://img222.imageshack.us/img222/2936/grill0437uy.jpg)
![](http://img377.imageshack.us/img377/9341/grill0446hg.jpg)
![](http://img377.imageshack.us/img377/7422/grill0461cz.jpg)
![](http://img377.imageshack.us/img377/8207/grill0458gw.jpg)
CEO, Team Anthracite
I've had this squeaking/rattling since about Month 3 of ownership. I took it in for servicing about 5 times but it was never fully fixed. I've lubed it up a bunch of times with silicone grease which helps in the short run but as mentioned by sebounet2005 you have to reapply the grease it after a few months.
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
