Whine from Engine Compartment
Hello,
I am getting a whine from the engine compartment when my 04 6MT gets up to operating temperature. Checked the power steering fluid, no bubbles, does smell burnt and is black. When I turn the wheel, the noise does not change pitch, only when I turn off the ignition the pitch gets higher just as the engine is stopping.
The noise sounds the greatest when I put my head next to the passenger front wheel well.
Any ideas?
Thanks in advance.
Chris
Any ideas?
Thanks in advance.
Chris
If this happens at certain speeds in lower gears, then it's normal. Ie. if there is a whine between 30-35mph, it's just normal tranny noise. I have had this checked by my dealer, a Acura/Honda Transmission Guy, and this forum. If this happens all the time, then I have no idea. =)
From you description about it being from the passenger wheel well..
Does the noise aggravate when you turn your wheel? - possible culprit: P/S
Does your noise aggravate when you accelerate? - possible culprit: Alt. Belt
If P/S is suspected.. is it cold where you are?.. and does it go away once the engine compartment has come to operating temps?
If Alt belt is suspected.. engage your A/C, does it get louder?.. check the alt. pulley, any belt shavings (black soot)? Are the belt ridges sharp or flat? Any noticeable wear?
.. I put my bet on the P/S especially if it whines when you move the wheel. Look for any P/S fluid seeping from the pump.
Noise stays the same when turning wheel, when reving engine it doesn't get louder, or I just can't hear it. The sound doesn't start happening until engine is up to temperature, no sound when cold. When engaging AC sound stays the same.
I will check the belt ridges today and reply back.
So I need to get my power steering check out, yes? I never went for the recall. Let me know asap; it's starting to worry me more and more.
omgoodness THANK you for pointing this out, because up here at school it hovers around 0-12 degrees F. Upon start up the whine is loud, and when I turn the steering wheel the noise is INSANELY loud.
- sound near left engine compartment where belts are.
- only starts making noise at op temp
- sound doesn't increase / decrease at RPM, engaging A/C clutch / compressor pulley, turning wheel
let us know if you see belt residue on the alternator housing and the condition of the belt overall.. could be something leaking on the belt after the engine has turned on like p/s fluid from your pump which may make your belt squeal / whine and could damage your drive pulleys (rust & corrosion). If you don't notice anything.. take it in soon and have it checked out.
lol.. my bad.. I figured that you've been on Azine so long that it would've come up. You can check your VIN as a sanity check to see if the recall has been done or not.. just in case they did the recalls when you last took it in for service.
The VIN check is below:
http://owners.acura.com/Maintenance/Recalls.aspx
call them and see if they can arrange to pick it up and deliver it.. otherwise it shouldn't take long to replace.
Brian ive told u my horror stories with my rack n pump..... do it do it! lol
what wheel well is it coming from see? if u press the clutch pedal down does the noise go away?
if it was missing the car would be pissing fluid all the time if it was incorrectly installed it would be pissing fluid as well... this piece is actually the wrong piece they didnt calculate the part correctly and they just put something in that didnt mate with the surface correctly....they probably ran more tests after my 4th rack and pump was changed to see what they f***ed up lmao now im in for my 6th i hope they can figure out what it is now
OK, checked belt, grooves look ok, outside of belt is turning like a tan color, and has some facial cracks on it. Car has 85K miles on it, time for new belt? How much would it cost, I have to go anyway for the wiper recall.
eww.. sounds like you're on some original parts.. definitely get a new one. If you want to do it yourself it's not a big deal. Just release tensioner - swap and tighten. Otherwise, take it in and it'll cost you about $100.
dude after my 3rd they found out the parts were trashed from the factory and storage facility they had a flood or something and the parts were corroded so they gave me a new rack off of a type s and its still shot... im just waiting for the weather to be a lil better and im gonna drop it off at acura to have it taken care of
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
