What is this wire and why is it stripping?
Old Mar 15, 2011 | 08:48 AM
Sondinh's Avatar
TEAM_SONIC
So I opened my hood today and noticed something interesting. I saw that some wiring was coming apart. Not sure what the function of this wire is and what is connected to. I drew a red arrow to show what I'm talking about.
My questions are:
1) What is the function this wire?
2) What is it connected to?
3) Why is the wire stripping?
Thank you for those who can help me find a solution to this in advance.
Old Mar 15, 2011 | 08:51 AM
Ground.
looks like corrosion got to it.
Old Mar 15, 2011 | 08:54 AM
SharksBreath's Avatar
BANNED
yup...should be a copper/bronze color.
corrosion city.
Old Mar 15, 2011 | 08:55 AM
Find some 4 gauge wire and replace it.
Old Mar 15, 2011 | 09:13 AM
jda123's Avatar
Dogmatic Dinosaur
You can buy grounding straps from auto parts stores too. Just measure how long you need it to be.
Old Mar 15, 2011 | 12:32 PM
user 0579729724's Avatar
09 Accord Coupe 6 Speed
Old Mar 15, 2011 | 03:32 PM
Sondinh's Avatar
TEAM_SONIC
Ground.
What is the ground for? How will I go about fixing it?
Old Mar 15, 2011 | 03:36 PM
jda123's Avatar
Dogmatic Dinosaur
To make sure that the electrical parts on the engine have a negative current for operation. Unbolt the piece and replace it. I imagine that the Acura dealer will have one if you want an exact fit. Otherwise, any suitable ground strap will do.
Old Mar 15, 2011 | 03:40 PM
You can see the two bolts holding the ground.
if you take these two bolts off, the ground wire will come right off.
Replace it with another ground wire, or as JDA mentioned, grounding straps...
Old Mar 15, 2011 | 08:10 PM
Sondinh's Avatar
TEAM_SONIC
Do you happen to know what the Acura part number for this ground trap? Thank you.
Old Mar 27, 2011 | 02:51 PM
Sondinh's Avatar
TEAM_SONIC
Does anyone know what the part number for this part?
Old Mar 28, 2011 | 04:57 PM
jda123's Avatar
Dogmatic Dinosaur
Go to the dealer and ask them, or pull up a schematic from acura.com.
Old Mar 30, 2011 | 09:58 AM
GoldnKnight22's Avatar
OOOOOH
Pretty easy to get a length of 4awg power wire and crimp on your own ring terminals...
Old Mar 30, 2011 | 10:09 AM
VQPower37's Avatar
this
Old Jul 10, 2011 | 04:03 PM
Sondinh's Avatar
TEAM_SONIC
I was looking through oemacuraparts website and try to look for this ground cable. Can someone please confirm this is the right ground wire.
CABLE, SUB-GROUND
Part number: 32610-SDA-A00
https://www.oemacuraparts.com/index....WIRE%20HARNESS
Thank you.
Old Jul 10, 2011 | 04:07 PM
friesm2000's Avatar
B A N N E D
that's one #9, but also #8 is another major one too (but yes the one you show in the pics is #9)
Old Jul 10, 2011 | 04:09 PM
Sondinh's Avatar
TEAM_SONIC
So I will need number 9 and #8 as well?
Old Jul 10, 2011 | 04:15 PM
friesm2000's Avatar
B A N N E D
number #9 is the part number you posted, the
CABLE, SUB-GROUND
then #8 is another major ground for the engine on the OPPOSITE end of the engine/transmission (it kinda sits buried down below the intake tube), and considering the ground you posted looks how it does, this ground (#8) probably looks in the exact same type of condition also
and as mentioned, you can also just go get some cable and make it yourself, or buy an universal one, but considering the price for OEM direct fit ones, not really worth the hassle to make anything else fit
Old Jul 10, 2011 | 04:21 PM
friesm2000's Avatar
B A N N E D
btw if you really want to cover yourself, and make the engine have good grounds, you could also replace the battery's ground too, which is #11 in this link
https://www.oemacuraparts.com/index....ponent=BATTERY
Old Jul 12, 2011 | 09:27 PM
Sondinh's Avatar
TEAM_SONIC
Not sure when you said "To make sure that the electrical parts on the engine have a negative current for operation." If I was to replace the wire myself, how would I do it correctly without harming anything. Thanks.
Old Jul 12, 2011 | 11:10 PM
swoosh's Avatar
takin care of Business in
+233245324 for replacing the wire with a 4 gauge wire....corrosion gets to you
Old Jul 14, 2011 | 04:13 PM
ashdec87's Avatar
As long as the car is off, you dont have to worry about anything. If you really feel nervous, disconnect the battery, but make sure you have the radio/navi codes with you.
Old Jul 14, 2011 | 04:18 PM
jda123's Avatar
Dogmatic Dinosaur
It can only produce 1.21 gigawatts as it sits. Most people can survive that if they touch it without wearing a rubber suit.
...or, just unbolt the old one and put the new one on. It is really that simple.
IBankMouse
Jun 13, 2020 12:53 PM
08KBP_VA
Oct 22, 2019 01:55 PM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
4drviper
Sep 23, 2015 07:42 PM
