Weird engine rattle
Weird engine rattle
Long time reader, but first time posting. 2007 acura tl, base model, great car. I love it. But in the last few months I have noticed that the engine has a rattling noise, but only between 1500 and 1800 rpm. It happens when cruising or accelerating through this rpm range. Not there when parked and engine revved into this range. Checked all heat sheilds and all thight. I had some misfire issues and found and resolved them with new plugs and a new coil pack. Car has 275000 kms and not sure if previous owner did the timing belt so thats next on the list. If the Gurus on this forum can help it would be appreciated.
Maybe I wasn't clear. The rattle is only when accelerating or cruising through the rpm range. At standstill with the engine going through the rpm range, no rattle. Also it doesn't matter what gear the tranny is in, or if it's in automatic or manual mode. I thought of the pulleys ot tensioner but why only at that specific rpm range?
hey i know this thread is old but did you ever figure out what this was? having the same issue with my 07
Hey man i’m having the same problem right now and just spend a few hours putting on a new belt tensioner and sound didn’t go away, only happens between 1.5-2.5k, you ever find a fix? starting to think it’s a loose heat shield or something like that
07DatTLS
Jul 18, 2011 11:07 PM
