Weird engine rattle
Old Oct 2, 2023 | 03:28 PM
Stevebaboolal's Avatar
Weird engine rattle
Long time reader, but first time posting. 2007 acura tl, base model, great car. I love it. But in the last few months I have noticed that the engine has a rattling noise, but only between 1500 and 1800 rpm. It happens when cruising or accelerating through this rpm range. Not there when parked and engine revved into this range. Checked all heat sheilds and all thight. I had some misfire issues and found and resolved them with new plugs and a new coil pack. Car has 275000 kms and not sure if previous owner did the timing belt so thats next on the list. If the Gurus on this forum can help it would be appreciated.
Old Oct 2, 2023 | 04:53 PM
csmeance's Avatar
Use a long screwdriver and check the accessory belt tensioner and alternator pulley; youtube how to do this before getting hurt!
Old Oct 2, 2023 | 08:19 PM
Maybe I wasn't clear. The rattle is only when accelerating or cruising through the rpm range. At standstill with the engine going through the rpm range, no rattle. Also it doesn't matter what gear the tranny is in, or if it's in automatic or manual mode. I thought of the pulleys ot tensioner but why only at that specific rpm range?
Old Mar 26, 2026 | 04:10 PM
SiteCommon1136's Avatar
6th Gear
hey i know this thread is old but did you ever figure out what this was? having the same issue with my 07
Old May 13, 2026 | 06:55 PM
jayacuratl05's Avatar
Hey man i’m having the same problem right now and just spend a few hours putting on a new belt tensioner and sound didn’t go away, only happens between 1.5-2.5k, you ever find a fix? starting to think it’s a loose heat shield or something like that
Old May 14, 2026 | 08:20 AM
Fl285's Avatar
9th Gear
The material inside the catalytic converter maybe loose.
conort2390
Jul 17, 2013 08:39 AM
07DatTLS
Jul 18, 2011 11:07 PM
brerpie
1G TSX Problems & Fixes
18
Apr 5, 2005 11:58 PM
XBrian
Mar 5, 2004 10:05 AM
