weird engine noise
weird engine noise
so last night i came home and parked in the garage and noticed a weird sound coming from the engine.. sounds almost like a motor dying and struggling to revive. should i be worried? its only got 3270KM (around 2000 miles) on it? ill try to take a video with sound and post it later
btw, i check the garage and found nothing
thanks
thanks
check your fluids and can you better describe the problem? What was the motor RPM? Was it warmed up?
I MAKE NO SENSE
Is it a whining type noise? if so plenty of people have had the same problems with their TLs. If you can reproduce the sound upon command, bring it to the dealer and show it to them (I heard Burrard Acura can be quite helpful).
Mike Bertram
09-10-2015 09:27 AM
