Warning - be careful with "Jig-A-Loo" !
Old Dec 1, 2007 | 12:22 AM
Steerpike's Avatar
I've been successfully using Silicone spray to silence a number of creaks and rattles (posted in other threads). Yesterday I picked up a can of Jig-A-Loo thinking it would be the 'same but better'.
Well, I sprayed it into the crack around the passenger air vent, and also into the gap above the wood trim on the passenger side door. I noticed, while spraying, that I could see 'frost' on the plastics, similar to the frost you get if you shake a can of 'dust off' before spraying - it's the propellant reacting. Anyway, today, I noticed a serious discoloration on the air vent, and also - even worse - serious damage to the clear coating over the 'wood' trim.
I'm going to try buffing both with something (any suggestions? I was thinking using a Mr Clean magic eraser, or something) to see if I can at least partially recover from this.
I went back to using silicone, with no problems.
I'm going crazy trying to stop creaks, squeeks, rattles, etc. Now I'm damaging my car in the process!
Old Dec 1, 2007 | 07:13 AM
dingdongman's Avatar
acetone might frost certain lacquer or plastics
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
jmaxima03
Sep 27, 2015 10:22 AM
TL14
Sep 24, 2015 04:37 PM
