Windows Fogged Up
Old Nov 25, 2007 | 06:56 AM
vz18wp's Avatar
3rd Gear
Unhappy Windows Fogged Up
Just purchased a 2008 TL. Drove for the past three days in 30 degree weather (F) and I can NOT keep any of the windows clear of fog without running the defrost function on HIGH FAN continually (tried it with RECIRC on and off, on produces better results! I have the A/C on and the defrost button selectednad heat temp HIGH. The rear passenger windows NEVER get de-fogged! What is going to happen when it really gets cold here in Michigan??? HELP!! Seems to me the A/C might not be working properly. Taking to dealer tomorrow.
Old Nov 25, 2007 | 10:20 AM
ltkaufman's Avatar
Check for moisture (wet) on the ft pasenger floor mat. Although rare, this sounds like a heater core.
Old Nov 25, 2007 | 03:46 PM
vz18wp's Avatar
3rd Gear
ltkaufman
Thanks for the heads up! I will check it out! Now that you mention it...it does smell a bit like radiator / heater core at times.
Old Dec 2, 2007 | 06:31 AM
vz18wp's Avatar
3rd Gear
Problem resolved by dealership. CAUSE= They found that the foil from dash insulation was NOT REMOVED from the fresh air inlet hole at the factory. They cut out the air inlet and reassembled...now operating normally!!! Just my luck, to pick this one off of the lot!!!
Old Dec 2, 2007 | 06:39 AM
P.R.E.A.M.'s Avatar
2K8 CBP TL-S 6MT
at least it was an easy fix dor them and didn't have to tare the car apart
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
Avenger411
Oct 11, 2015 03:53 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
rhdune16
Sep 28, 2015 11:31 AM
