Valve Adjustment
Old Nov 17, 2022 | 01:07 AM
Mpham626's Avatar
4th Gear
Valve Adjustment
Hello,
My 2006 TL has 110K miles. Should I do a valve adjustment? And what are the benefits of a valve adjustment?
Thank you!
Old Nov 17, 2022 | 07:28 PM
csmeance's Avatar
For the best performance and fuel efficiency I always recommend when doing a timing belt service since everything is apart including new valve cover gaskets. Did you have the 105K timing belt service done?
Old Nov 17, 2022 | 07:33 PM
Mpham626's Avatar
4th Gear
I did but before 105K. Didn’t know I needed to do valve adjustment.
Old Nov 18, 2022 | 06:55 AM
rockstar143's Avatar
You don't "need" to but it's good to ensure the tolerances are within spec every once in a while...if engine idles pretty quietly, I wouldn't sweat it.
Old Nov 18, 2022 | 04:52 PM
csmeance's Avatar
It's not needed, but certainly helps keep the motor running perfectly. I would wait until the next time you need valve cover gaskets or when the valves start getting noisier. Sometimes the valves can get out of spec and cause misfires, esp when not using premium fuel.
Old Nov 19, 2022 | 06:43 AM
Superunknown's Avatar
I had mine done with the valve cover gaskets. Everything was in spec. It's nothing to lose sleep over.
Old Nov 20, 2022 | 11:01 AM
Not running premium sounds like an owner that definitely wouldn't worry about a valve adjustment. LOL.
I did the valve adjust on my TL-S the first time around at about 130K...then I think I checked them again at like 190K when I bought it back
and now that it's at 240K it still runs and drives SO smoothly!
Old Nov 28, 2022 | 07:31 PM
Ltfa182's Avatar
Picked up mine at 164k. Had a valve adjustment done as a part of all the other work I was having done. He mentioned they were a little off on some of them, but nothing was too crazy.
Gullyguy
Dec 29, 2021 06:19 AM
Tsx780
Jan 1, 2018 02:12 PM
whatwasthat
Aug 10, 2006 12:40 AM
