Valve Adjustment
For the best performance and fuel efficiency I always recommend when doing a timing belt service since everything is apart including new valve cover gaskets. Did you have the 105K timing belt service done?
It's not needed, but certainly helps keep the motor running perfectly. I would wait until the next time you need valve cover gaskets or when the valves start getting noisier. Sometimes the valves can get out of spec and cause misfires, esp when not using premium fuel.
Not running premium sounds like an owner that definitely wouldn't worry about a valve adjustment. LOL.
I did the valve adjust on my TL-S the first time around at about 130K...then I think I checked them again at like 190K when I bought it back
and now that it's at 240K it still runs and drives SO smoothly!
