unlock door headlights turn on?
Old Oct 26, 2009 | 02:25 AM
sebas809's Avatar
Question unlock door headlights turn on?
my friend had a tl a few years ago and when the car was locked and you hit the unlock button on the remote the headlights would come on, on the tl that i bought the headlights dont come on until I physically open the door..... is there a way of changing this? mine is an 04 his was either 04 or 05 im not too sure
Old Oct 26, 2009 | 05:49 AM
dommafia's Avatar
04TL4L
Hmm i have an 04 model and I usually leave my lights on then tap the lock button on the remote 2 times to make them turn off. When I hit the unlock button they turn on immediately .
Old Oct 26, 2009 | 06:08 AM
01tl4tl's Avatar
check the owner manual for your year--it seems to have changed at some point on how to activate this feature
here is the free owner book link if you dont have one- click year then model
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Old Oct 26, 2009 | 06:56 AM
blkaspec's Avatar
Full of water...
i have an 06...and if i leave the lights on and turn off the car and lock the car with the fob(x2) the lights turn off, and then when i hit the unlock button they turn on. if you dont hit it twice to lock they will turn off, but not for a few minutes. the trick is to leave them on all the time.
i dont advise this because you will cause excess wear on the light components if you are turning them on and off and not allowing them to fire up all the way. if you just need to grab something out of your car quick you will be unnecessarily turning them on which will cause them to burn out quicker.
Old Oct 26, 2009 | 07:23 AM
Dan1629's Avatar
Registered Member
On my car 07 type-s all those settings are in the set up menu.I know on my car I can set all kinds of things to happen or not when using the remote.
Old Oct 26, 2009 | 11:51 AM
01tl4tl's Avatar
blkaspec is correct- it does cause extra wear on HIDs to fire them up the immedialty off...actually its refiring them immedialty that really puts the hurt on them
I drive with my lights on most of the time but park with them off since I installed kaixen bulbs (gen2) It was cheaper to install better driveway/walkway lighting for the wife than leave the car lights in ~visual help to the house door~ mode
Even found 6000k lights at lowes for the outdoor lights- matches the car lights!
Old Oct 26, 2009 | 11:56 AM
SpecTro's Avatar
hmm this happenes to me randomly. Usually when i hit the unlock button my lights turn on, but very randomly i would have the think when i would have to open the door for the lights to turn on.
Old Oct 26, 2009 | 01:44 PM
gdong's Avatar
About the lights on then off issue, I use auto headlights and during the day, when I drive into the garage the HIDs will come on, then I'll turn the car off. This is going to cause the same wear and tear eh?
Old Oct 27, 2009 | 09:23 AM
sebas809's Avatar
i changed the "headlight auto off timer" from 0s to 15s and now the lights come on when I press unlock on the remote, thanx for ur help
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
JnC
Sep 11, 2015 06:06 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
