Turn signal went bad
Old Mar 16, 2014 | 12:03 AM
thorws's Avatar
my passenger side turn signal no longer lights up when I turn on the headlight. I thought it was burned bulb but when I activated passenger turn signal, it still worked and flashed.
can you guys tell me what happened? is it a fuse or something?
Old Mar 16, 2014 | 10:22 AM
subinf's Avatar
One on the right for me
Same thing on my car. Works when I lock it but not when signaling. I haven't fixed it but I believe it's the relay.
Old Mar 16, 2014 | 02:15 PM
thorws's Avatar
[QUOTE=subinf;14923646]Same thing on my car. Works when I lock it but not when signaling. I haven't fixed it but I believe it's the relay.[/QUOTE)
thanks for the reply. Well, guess I'll have to leave it like that then
Old Mar 17, 2014 | 08:20 AM
bla8291's Avatar
I could be wrong, I was actually thinking that one of the filaments are bad since it's a dual filament bulb, which explains why you get full brightness (flashing) but not half brightness (headlights on). So in that case you'd have to replace the bulb.
Old Mar 17, 2014 | 06:22 PM
thorws's Avatar
interesting, I'll check the brightness level tonight. The last time I checked, it did appear a little bit dim. But that may be just me imagining it.
Old Mar 17, 2014 | 11:50 PM
subinf's Avatar
Does your tail light blink?
Old Mar 19, 2014 | 11:57 PM
thorws's Avatar
yes, it does. I'm starting to think it is one of the filaments. I will put new bulbs in and check to see if they are indeed due to the bulbs
Old Mar 20, 2014 | 01:24 AM
subinf's Avatar
Start with the bulb. Pull the left one out and put it in on the right and see what happens. Could be an easy fix.
Old Mar 20, 2014 | 08:17 AM
bp_spets's Avatar
One of the filaments burnt out. the front turn signal is a dual filament bulb.
pplcrew
Jan 30, 2021 08:59 AM
Greengecko
Sep 16, 2015 08:19 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
