Trying to Replace Spark Plugs myself, Help please~
Old Sep 25, 2011 | 09:14 AM
Cronos2010's Avatar
Smile Trying to Replace Spark Plugs myself, Help please~
Hi members~
I am trying to replace spark plugs by myself~
Acura dealership is asking me way over price than the price that I was expecting so...
I would be greatly appreciated if you guys could help me out.
Thanks,
John
Acura TL 2004
Toronto,ON
p.s please attach or put photos. Thank you guys
Old Sep 25, 2011 | 09:35 AM
Turbonut's Avatar
No photos but fairly easy if you've done it before on any car:
https://acurazine.com/forums/3g-tl-2004-2008-93/07-spark-plug-change-832770/
https://acurazine.com/forums/2g-tl-problems-fixes-117/changing-spark-plugs-639382/
Here's a pic with the coils/plugs out:
https://acurazine.com/forums/3g-tl-2004-2008-93/122-diy-105k-service-timing-belt-water-pump-spark-plugs-thermostat-%2Apics%2A-784622/
After coil removal I blow out the area befores removing spark plug. I also use a rubber hose attached to the top of the plug to get it started and never-seize on the threads. Don't over-tighten the plugs.
Rock Auto-NGK 6994 $9.77 each + shipping.
Use code 65984515480936 in the where did you hear about us and get an additional 5% off parts until 10-11-11.
Check other part stores for their current price.
Old Sep 25, 2011 | 09:42 AM
Cronos2010's Avatar
Hello Turbonut, thank you for your reply...I have no experience on replacing or maintaining cars by myself before...so...
What kind of equipment do I need to do this?
Old Sep 25, 2011 | 09:50 AM
Turbonut's Avatar
Here's some pics from the 2G:
http://www.socom.acura-cl.com/forums...d.php?t=760163
Old Sep 25, 2011 | 11:13 AM
I hate cars's Avatar
You need a spark plug socket which will have a rubber 'gripper' to hold the spark plug in the socket when removing it. A few different lengths of extensions. A swivel, and a 3/8" drive ratchet. With the right extensions it will be a very easy job.
The entire job is basic hand tools. You can remove the strut brace bar to give you more room to work. I don't think I did but most do.
One thing to remember, if you're using a torque wrench to tighten it, it becomes invalid if you're using a swivel. Use anti-seize on the spark plug threads. Just a dab, not much required but it's a necessity on aluminum headed engines like the TL. Thread the plugs in as far as you can by hand before using a ratchet.
Plugs should come pre-gapped. It doesn't hurt to check though. If you drop one or bang one, recheck the gap.
I agree with turbonut, it's a great idea to blow the hole out before removing the plug.
Old Sep 25, 2011 | 01:15 PM
Cronos2010's Avatar
Thank you very much guys for helping me out!!
Old Sep 25, 2011 | 04:56 PM
CGCINC's Avatar
I just did it and did NOT remove the strut bar. It only got in my way on one spark plug on the right rear of the engine. If you remove the strut bar I think it would make life easier!
Old Sep 25, 2011 | 05:55 PM
rockstar143's Avatar
Take your time...do it on a cool engine and just rest on it and take it slow. I think I did all 6 of mine in 45 minutes. Fronts took 10 minutes and 35 for the back 3.
Old Sep 25, 2011 | 09:28 PM
ohsixMTee's Avatar
Early Shifter
Is 105K a realistic interval for our spark plugs? IMO That sounds a bit high....
Old Sep 26, 2011 | 06:26 AM
Turbonut's Avatar
No problem with that mileage. I've posted this before, due to my lack of scrutiny, the daughter's Maxima had 137,000 on the OE plugs, no problems before they were changed and ran the same after they were changed. They've come a long way in ignition/plug design.
Old Sep 26, 2011 | 11:26 AM
ohsixMTee's Avatar
Early Shifter
Cool, thanks for the input.
Old Sep 26, 2011 | 12:02 PM
CGCINC's Avatar
I just replaced our plugs at 208,000 miles. We bough the car with 54,000 miles and I have never changed or had them changed. I didn't feel any difference but I'm sure it needed it..lol
Old Nov 8, 2013 | 06:35 PM
Benefield's Avatar
3rd Gear
Good info. Thanks guys.
cycdaniel
Dec 17, 2019 10:58 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
NSolace
Sep 3, 2015 08:14 PM
robowarrio
Sep 1, 2015 09:25 PM
quake97
Aug 30, 2015 07:57 PM
