Trunk leaks
Old May 19, 2006 | 12:03 PM
NBAST TL's Avatar
6th Gear
Trunk leaks
Hi, I'm new to this forum and have a third generation TL but was wondering if anyone else was dealing with some sort of leak in their trunk. Noticed a musty odor and now noticed it was from water getting in some how Anyone having this problem?
Old May 19, 2006 | 04:54 PM
A_UFO's Avatar
No problem with water leaks in my 05 TL trunk.
Get the garden hose with a friend you trust. Get in the trunk with a flashlight, close it and have your friend water the car to see if you can spot where the water is leaking into the trunk.
At least you can point this out to the dealer when you take the car in for service.
Old May 22, 2006 | 07:14 AM
NBAST TL's Avatar
6th Gear
Thanks A_UFO, that's clever, hadn't thought of that. Now to find someone I trust to unlock me from the trunk... The good thing it's very little water just enough to wet the carpet. Thanks again, I'll let you know how I make out.
Old May 22, 2006 | 12:08 PM
Will Y.'s Avatar
Registered but harmless
With friends like that...
If you have friends like I do, carry a remote fob into the trunk with you so that you can get out while your friend(s) may be ROFL...
Old May 22, 2006 | 06:27 PM
A_UFO's Avatar
Actually, there is a trunk release on the inside of the trunk deck lid. It glows in the dark. Although, it is good to make sure you can get out in case of mechanical failure.
Old Aug 3, 2006 | 12:36 PM
missmybeemer's Avatar
4th Gear
I had an inch of water in my trunk! (06 TL) Brought back to dealer. First they wanted to blame my Sirius antenna running out of the trunk. After I told them they were nuts they determined that the trunk seal gasket needed replacement. Seem ok now,
Old Aug 3, 2006 | 07:19 PM
Kracker's Avatar
05 TL
Take the side panels in the trunk off. There is a clear tube that comes from the drain on each side. Its just stuck in another tube.
Or the gasket is bad. Perhaps the adjustment for the trunk isn't correct.
If you can, take it to the dealer. Odds are they will replace all the carpet in the trunk... Oooo What about wires that are now corroding.
Old Aug 3, 2006 | 10:24 PM
havokgroup's Avatar
As mention ...use the garden hose method (make sure you can get out). More than likely it's the trunk weather stripping or the tail light gasket.
Old Aug 25, 2006 | 02:10 AM
dplaya746's Avatar
That part made me laugh really hard
Old Dec 9, 2006 | 02:13 PM
hoangtanle's Avatar
KidWiTh2kTL
is trunk leak covered under warranty?
Old Dec 9, 2006 | 02:31 PM
acura911's Avatar
Yes
Old Dec 10, 2006 | 11:48 PM
hoangtanle's Avatar
KidWiTh2kTL
Thanks a lot. i will bring my Acura in before i go to florida! haha so they can fully check up on the car cause they messed up my alignment when i went to get my tranny fixed. i have a friend work there and he said keep bringing it in cause they get lazy sometimes.
Old Dec 12, 2006 | 10:42 PM
Inaccurate's Avatar
Here is a pic of the tubes in the trunk that drain the sunroof area..
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
