Trouble Starting the car
Old Apr 16, 2010 | 09:01 AM
Chistyle's Avatar
3rd Gear
05 TL. I have trouble starting it. First started happening when I would fill up the gas tank. I thought it was bad gas tried different stations and it was better but over the last week anytime i drive the car short distances or if its off for awhile it does the same thing. Acts like the battery is dead but after a few turns and pumping the peddle it works. The clock resets at 100 but then goes back to normal time once the navigation turns on. I tried fuel injector cleaner thinking maybe the fuel wasnt getting there and nothing. Could this be a Fuel Filter, Pump, maybe the battery?
Old Apr 16, 2010 | 09:42 AM
Will Y.'s Avatar
Registered but harmless
I'd check the battery and battery connections first, but bet on the battery needing replacement if it's the OEM battery.
Old Apr 16, 2010 | 10:49 AM
Chistyle's Avatar
3rd Gear
I check the battery cleaned the terminals. I have 86k miles. Should i tune it up?
Old Apr 16, 2010 | 11:02 AM
nfnsquared's Avatar
How did you check the battery?
How did you clean the terminals? Did you loosen and remove the cables from the battery terminals, clean the terminals and cable clamps, and then re-tighten?
Old Apr 17, 2010 | 07:09 PM
eg5's Avatar
eg5
user title goes here
i suspect a faulty battery.
k nowing how you mention the clock reads 100
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
