Trouble With RSB
Dude!!
You have to use an Allen Key to hold the bolt. It's either a 5mm or 8mm (don't recall) in the end of the bolt THEN turn the nut.
(That for the End-Link bolts, not the Bushing bolts).
Originally Posted by HigdonTL05
any reason that its like that thanks by the way
Don't know why. There are few nut/bolts like that. The ones on top of the struts for example.
I guess it prevents certain critical parts from unscrewing themselves.
acutually i didnt i still couldnt get the nuts to move, there really tight on the bolts just might take it to acura and have them put it on. oh and i kind of stripped the hex out of the bolt
Aw, man that sucks.
Don't know what to tell ya. Hopefully Acura or a local indie shop (seems like everywhere has an indie Honda/Acura specialist or two) will be able to take care of it for you.
Maybe someone will be along that can give you a better suggestion.
GL
GL
um.. if you kept turning it without holding down the hex nut, you may have stripped it... and now it wont tighten right??
might need new end-links now... i think they are like $30-40 each...
If I were you, I would talk to mr. heel toe, he has a group buy going for aftermarket endlinks, which seem like money...
Rockauto.com has the MOOG replacements for about $20 each.
So i can get new end links with the bolts for 160?????? how do i remove the old ones?
You can OE replacement Moog's for ~$40 or $50.
You can get Acura OEM parts for ~$80.
With your stripped bolt/nut, I can't offer suggestions on removal. On the unstripped ones, just hold the bolt with the Allen Wrench and undo the nuts.
