Transmission slop… ?
Old Jun 17, 2015 | 07:14 PM
Max Attitude's Avatar
I have an 07 TL with 121k miles on it. When shifting to drive or reverse when in park I hear a "clink". I can also hear it when taking off from a stop sometimes. Seemes to have gotten worse in the past couple of days so tonight I pulled the wheel off (driver's side) and it seems to be something in the trans. It is not slop in the axle itself. It will make the noise when turning the hub forward and back again. Anyone else experience this? This is our 3rd, 3rd gen TL and the other 2 never had this issue and they had more miles. (05/08 TypeS)
Bought the car with 75k and had the trans flushed soon after.
I changed the gear selector/sensor this winter because I was getting a code and going into limp mode. It was good for 2-3 months. About a month ago it went into limp mode again but that was the only time and has been fine since. Related? I'm fearing it will need to be rebuilt.
Old Jun 18, 2015 | 07:36 AM
JMiles_T's Avatar
Check your motor mounts to make sure none of them are torn. A torn mount can allow the engine to rock back and forth under the hood depending on how much torque is being put to the wheels.
Old Jun 18, 2015 | 10:41 PM
Yeah it's not that. I can have it make the noise while under the car without it moving the engine/trans. Thanks for the input though.
Old Jun 18, 2015 | 10:50 PM
1fstTL's Avatar
don't forget the transmission has mounts 2.
Old Jun 19, 2015 | 08:01 AM
Makes the noise without that moving.
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
