Transmission Issues
Old Jun 19, 2025 | 02:03 PM
CenturionTL's Avatar
Transmission Issues
For my 2005 Acura TL Auto, when I change from park to reverse it takes a few seconds for the gears to engage. I can feel when the gears change. Sometimes it hard shifts into gear, and if I don't wait a few seconds after changing it into reverse, the car slowly moves and RPM goes high till it engages. Is my transmission failing or can this be fixed with bolt on parts such as a transmission solenoid or pressure switches? Thanks for any info.
Old Jun 19, 2025 | 03:20 PM
csmeance's Avatar
Hows the fluid level and condition? How many miles on the trans and the fluid? The delay is usually caused by low line pressure in the hydraulics of the trans vs a solenoid sticking or being worn.
Sonnax makes a few rebuild kits to correct issues like this but they require a full rebuild vs "bolt on" parts like you mention. https://www.sonnax.com/units/478-honda-acura-5-speed
Replacing pressure switches may help improve shift quality. Also, have you ever changed the transmission fluid filter?
Old Jun 19, 2025 | 04:30 PM
My original transmission kicked the dirt and I put in a reman transmission bought from AutoZone. It is now 4 years old with approx 10k miles on it. It looks like it's a reman transmission from an accord, unlike the original transmission it doesnt have the area where the transmission filter was or where you fill the tranny fluid. The warranty expired last year. I need to have the transmission removed and rebuilt? Could this issue possibly fix it self on its own?
Old Jun 19, 2025 | 04:39 PM
It takes 2-3 seconds to engage in reverse, it doesn't do it immediately. You can feel when the transmission gets into gear.
Most importantly is the transmission going to kick the dirt, or will the delay in gear engagement be the only problem? It only does it when putting it in reverse.
Old Jun 19, 2025 | 07:45 PM
csmeance's Avatar
2-3 seconds can be "normal" for older transmissions but yours is rebuilt with only 10k miles. I would say drive it until you can't drive it anymore!
Old Jun 21, 2025 | 08:16 PM
Now it's starting to hard shift when starting to drive from a stop (1st gear). It does not do it every time, but once in a while. It also did it once when driving last week (don't know which gear). Is the end coming near?
Old Jun 22, 2025 | 05:28 PM
csmeance's Avatar
Check the fluid level and we can go from there. What color is the fluid?
Old Jun 23, 2025 | 02:35 PM
Fluid level is at max on dipstick indicator, and it's red.
Old Jun 23, 2025 | 03:48 PM
I replaced it with this exact one (it had 3 year parts and labor warranty with unlimited miles):
National Powertrain Remanufactured Automatic Transmission Assembly T295606 (autozone.com)
It doesn't have a transmission fluid fill hole like the original tranny had. The remanufactured tranny didn't come with the invoice that states which original core the transmission was remanufactured from.
I called National Powertrain and Autozone and they couldn't tell me the original model of the transmission.
I was going to ask if you were still within the 3 year warranty; however, it appears you are well beyond that now in June 2025, unfortunately.
Old Jun 23, 2025 | 08:17 PM
csmeance's Avatar
The page linked in the post above from autozone says BDGA trans code which is the TL and not BAYA like accord.
Old Jun 24, 2025 | 12:22 PM
Behind the driver side front wheel there was a gear switch, I forget what it is called, I replaced it with an aftermarket one a while ago, could that be the culprit?
Old Jun 24, 2025 | 06:01 PM
csmeance's Avatar
Unless it's out of adjustment it shouldn't cause any issues. I'm assuming this is the range switch (controls park, reverse, neutral and drive)
VisualEchos
2G RDX Problems & Fixes
97
Jul 24, 2025 05:25 PM
ericcdong
Mar 18, 2016 07:11 PM
ericcdong
Aug 23, 2015 02:55 AM
austinjh
Jan 23, 2012 10:45 AM
thewrangler99
Jul 20, 2010 06:30 PM
