Transmission help
Old Dec 19, 2008 | 01:48 AM
erick3's Avatar
Transmission help
Just a quick question: I'm hoping all of you can relate.
I have an 05 TL, and it has around 72k on it. It's been good to me all these years and I haven't had any MAJOR problems with it. My transmission, on the other hand, seems to be acting up. I'm assuming the majority of you have ridden in some sort of older accord. You guys all know the sudden drop in rpms when you go from 1st to 2nd in those things (nothing below the expected rpm during say idling, but a drop in the sense that from 1st to 2nd it just...feels unnatural?) It isn't smooth, but rough and almost forced - can be felt with a little foot on the throttle? You guys know what I'm talking about???! It's frustrating trying to explain...!!! Anyways, I HAVE THAT. I just did a flush and I can't seem to get rid of it! 2nd to 3rd, the car shifts normally - smooth and PERFECT. THAT DAMN 1st to 2nd gear change...just isn't the same anymore........................................... ........................ya guys feelin' meeehh?!?!?! lol
THANKS ALL!!!
Old Dec 19, 2008 | 02:58 AM
subbuzz's Avatar
07 tl-s in
I hope I'm not jacking your thread but
I dunno if it's just because I just had a 08mdx loaner that shifted smooth as butter, but my 07 tl-s alway's seemed to have rough shift's at lower rpm's from day 1. Now after a week with the mdx I really notice how harsh the shift's are. It seem's like when I give her more gas (like 1/2) and a higher rpm the shift is smoother.........
Old Dec 19, 2008 | 05:48 AM
erick3's Avatar
nah man, it's kewl. that's exactly what i'm talking about! except mine seems to be progressively getting worse...seemingly that is. light foot on the gas pedal and the shift almost seems out of place...why go up as high as 3k (ish or sometimes a little below) and then shift? ecu learning my typical driving habits? i think more or less NOT...why why why...? anyone?
Old Dec 19, 2008 | 10:32 AM
01tl4tl's Avatar
when you say FLUSH do you mean you changed 3 qts of trans fluid- or did a 3qtsx3 times method? or a machine at a shop?
What fluid was used- ONLY Honda ZR1 is approved- dextron will kill your trans
Do you get a slight shudder feel, or slipping of the clutch as it shifts?
What happens when you run it full throttle getting on the freeway?
05 carries many of the same gen2 problems with clutchpack failure~
Old Dec 19, 2008 | 10:34 AM
01tl4tl's Avatar
the ecu only does a relearn if you disconnect the battery NEG cable or pull the CLOCK fuse- #13 on passenger side of dash or footwell
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
