Transmission or clutch issue?
Old Jul 24, 2020 | 11:04 AM
Shotguntuck's Avatar
4th Gear
I've been wrestling for a while now and I'm at the end of my ropes, hopefully someone can help me out. It started with my shifter being notchy In all gears, it was bad, I had to baby the trans. I though it might be a badly installed clutch, so I replaced the clutch. I drove it for a day then randomly I heard a really loud POP and all my gears were gone. I could shift through them but there was no power to the wheels. I though maybe it was the clutch coming loose so I replaced it again. Nothing. At that point I figured it could only be the transmission. I just finished putting a new transmission in and it's the same problem. I have no idea where to go now. Anyone have any idea what it could be?
Old Jul 24, 2020 | 02:01 PM
csmeance's Avatar
master cylinder/slave cylinder working properly?
Old Jul 24, 2020 | 03:18 PM
WDPanda's Avatar
push clutch in, have someone check your slave cylinder pushing the transmission fork. That'll tell us your hydraulic is working.
Old Jul 24, 2020 | 03:46 PM
Could be a broken Axle as well
Old Jul 25, 2020 | 06:09 AM
4th Gear
Yes I can see the slave cylinder depressing all the way. But I can shift through all the gears with no clutch anyway
Old Jul 25, 2020 | 08:29 AM
horseshoez's Avatar
Latent car nut
I second @thoiboi, broken or not fully inserted axle.
Old Sep 10, 2020 | 12:19 PM
showallen's Avatar
Hello,
I had that exact same problem happen to be this morning. I drove off from a stop light and hear a pop. Clutch goes in and out and can go through all the gears but can't won't move at all. I thought it was the clutch but after reading more thinking it could be the axle now. Car will be looked at by my local Acura dealer in the morning
Wondering what ended up being the issue for the OP?
-Brian
Old Sep 10, 2020 | 01:33 PM
Originally Posted by showallen
Hello,
-Brian
the axle would be simple enough to observe if you go under the car and see
Old Sep 10, 2020 | 01:37 PM
Hello,
-Brian
well, OP replaced cutch and tranny..Didnt solve his problem..
most likely Axle. especially since you heard a pop.
Old Sep 14, 2020 | 11:00 AM
showallen's Avatar
Update,
It was the left axle.
BigBuffetPocket
Sep 8, 2017 07:19 PM
pache
1G TSX Problems & Fixes
Sep 22, 2006 12:44 PM
kaushikbala
25
Aug 2, 2006 08:12 PM
goredcar
Jul 14, 2005 03:43 PM
BigBrother
May 11, 2004 04:23 PM
