Tranny slip, jerk, slow reverse engaging
Old Jul 22, 2013 | 03:21 PM
nimish600's Avatar
Hey guys,
While driving my car seems to jerk while changing gears as well as while being in the last gear on the highway I will feel jerks. This started happening yesterday in 80F+ weather with the A/C on. I hardly use my A/C.
during take off it will feel like the car is in neutral and then jerk into gear
during reverse it won't engage until about 5 seconds, it'll feel like it's in neutral.
I changed my transmission fluid recently 1 month ago
Old Jul 22, 2013 | 03:46 PM
Comptechtl2367's Avatar
Did you change your sensors at all?
What year and how many miles?
Old Jul 22, 2013 | 05:09 PM
nimish600's Avatar
I have about 160,000 miles, I haven't changed my sensors at all.
I am thinking about doing a timing belt change since I haven't done that at all since I've bought the car as well as a power steering pump change as my steering is very hard when stopped. Do I change the water pump when I change the timing belt and the power steering pump?
Old Jul 22, 2013 | 11:55 PM
Gil'sUA5's Avatar
A short delay is normal when putting it into gear, the transmission on my 05 is in top shape and it still takes about a second (which feels more like a minute) for it to engage in drive or reverse. Our cars do not engage in the drive gears instantly.
Old Jul 23, 2013 | 11:53 AM
nimish600's Avatar
so while driving on the freeway, I press the accelerator pedal and the RPMs shoot up but it seems like the car is in neutral and then all of a sudden it catches and then goes into the gear and jerks.
Does that make sense?
Old Jul 23, 2013 | 01:24 PM
SlimTL's Avatar
Nope.
Tranny is headed to no man's land.
Old Jul 23, 2013 | 02:16 PM
I hate cars's Avatar
Check the fluid level first. If that's ok, you're probably going to be out of luck. If it's an '04-'06 there's an external filter you can check. The switches should have been replaced a long time ago and may help a little but they're not going to fix it completely. If none of this helps swap the fluid with some cheap Type F fluid to help limp it along a little longer.
Old Jul 24, 2013 | 02:36 PM
nimish600's Avatar
Just took it to AAMCO, they confirmed it's a 3-4th gear and drum. My car is an 2006, where is this filter? They told me the filter was inside.
They said to rebuild the transmission, I'd rather just put the money I would pay for a transmission re-haul on a new car though.
Old Jul 24, 2013 | 03:25 PM
paperboy42190's Avatar
i wouldnt recommend aamco
Old Jul 24, 2013 | 04:17 PM
Slpr04UA6's Avatar
-------Tim-------
Pressure switches thread
https://acurazine.com/forums/3g-tl-2004-2008-93/very-interesting-conversation-my-transmission-builder-tl-721508/
External tranny filter thread
https://acurazine.com/forums/3g-tl-2004-2008-93/c-036-diy-transmission-filter-replacement-pics-787078/
DIY tranny fluid 3X3
https://acurazine.com/forums/3g-tl-2004-2008-93/c-026-diy-changing-atf-pics-745892/
Old Jul 28, 2013 | 11:37 AM
mb1976's Avatar
Dude, I would just get a new car as long as you're not upside down on your TL meaning owing more then what the car is actually worth
Old Jul 28, 2013 | 08:48 PM
Alexns05's Avatar
Terrible financial advice. You must be a member of Congress!
Old Jul 29, 2013 | 10:23 AM
YeuEmMaiMai's Avatar
there are 2 filters one under air box and one inside the transmission.
Old Jul 29, 2013 | 10:50 AM
BwhiTL13's Avatar
Honda Service Advisor
so the short delay going into a gear is normal for an 04 TL?
Old Jul 29, 2013 | 12:48 PM
nimish600's Avatar
so yesterday the transmission started downshifting on the freeway at 70mph-80mph. downshift then go back to normal.. I stopped driving it and have already ordered the pressure switches... I hope it's not toast though.
Old Jul 30, 2013 | 08:19 PM
Alexns05's Avatar
Correct.
Old Jul 30, 2013 | 10:13 PM
MEKO's Avatar
I have the samething. Just started yesterday.
A big delay between gear engagements.
Yes It started on a day with hot 80F outside and while a/c was on.
I barely use a/c as well.
Got the check engine light by the end of the day.
Gave me these codes.
PO420
PO741
Old Jul 31, 2013 | 10:17 AM
swoosh's Avatar
takin care of Business in
sub'd to see if OP gets the same CEL
Old Jul 31, 2013 | 10:55 AM
new trans time
Old Aug 1, 2013 | 05:02 PM
nimish600's Avatar
Just got my 3rd 4th gear pressure switches in.. let's see if there is any improvement which I doubt there will be :-(.
I did not get a CEL but did get a flashing D light that went away.. as well as when I tried to switch over to manual mode the LCD did not show me what gear it was in and was actually blank. I did come back after a few mins of the car being turned off then back on.
Old Aug 1, 2013 | 05:14 PM
MEKO's Avatar
That didn't happen to mine, no flashing or anything, was able to shift it the whole day however I wanted
Good luck..
Is this how your tranny dipstick look like. I mean the oil level..
Old Aug 2, 2013 | 01:48 PM
nimish600's Avatar
Getting the switches changed right now.. Let's see what the verdict is...
Old Aug 2, 2013 | 06:26 PM
nimish600's Avatar
didn't work.. I need a new trans.. so to rebuild or buy a used one? What are the failure rates on both?
Old Aug 2, 2013 | 11:44 PM
MEKO's Avatar
High of course, it's an AT
Did you replace the fluid?
MT swap may be? Where are you located?
Old Aug 3, 2013 | 10:08 AM
swoosh's Avatar
how does the fluid smell? does it have a burnt smell to it?
do you have any codes?
did you do a drain and refill? excessive shavings on the plug? did you change your transmission filter?
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
STC
Sep 23, 2015 04:36 PM
