Tranny Fluid Flush?
Tranny Fluid Flush?
My friend works at Jiffy Lube and i was wondering if i should go there to get my tranny fluid flushed and replace the tranny oil with some oem one from honda?
is there any filter i have to change ? do i have to change preesure switch and all that ?
i have a 2007 acura tl type-s
i wouldn't trust any type of flush for either the transmission or the engine. there can be some very adverse effects on sealed parts and future oil/fluid integrity.
If it's been awhile do the 3x3 change. Use 3 quarts of OEM fluid 3 times in a row. You can research all info on it in the 3G garage. If you feel that you don't need to do a 3x3 change then you can do a regular 3 quart change every 15k-20k miles. <<That's my preference and I'm going 102k miles strong. I also replaced my pressure switches at 100k miles so that's your call on those.
Search is your friend: (not sure if you have AT or MT)
https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
https://acurazine.com/forums/ramblings-12/anybody-good-xp-89064/
https://acurazine.com/forums/ramblings-12/valentines-day-haiku-93452/
https://acurazine.com/forums/car-talk-5/omg-audi-a4-1-8t-114948/
https://acurazine.com/forums/showthread.php?t=120619
https://acurazine.com/forums/showthread.php?t=146299
https://acurazine.com/forums/3g-tl-2004-2008-93/c-026-diy-changing-atf-pics-745892/
https://acurazine.com/forums/3g-tl-2004-2008-93/optimal-percentage-racing-atf-834299/
https://acurazine.com/forums/3g-tl-2004-2008-93/c-036-diy-transmission-filter-replacement-pics-787078/
https://acurazine.com/forums/3g-tl-problems-fixes-114/c-036-transmission-filter-change-how-pics-789433/
https://acurazine.com/forums/showthread.php?t=89064
SharksBreath (04-30-2012)
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
