Torn engine mounts (pics inside)
Old Mar 16, 2010 | 09:14 AM
vinuneuro's Avatar
There's been a lot of vibration in the cabin lately. Both when standing still in Driver or Reverse, and at 50mph in 5th.
So I took the passenger side cover off in the engine bay, and found that the side engine mount is torn. Looking at it, I think this may be just an outer dust cover, but maybe torn from excessive engine movement?
I'm going to replace this side mount. But I'm also wondering about the front and rear mounts. From what I've read, it seems the front mount is pretty prone to failure, but it doesn't seem to be leaking at all. Looking at the engine movement, it looks a bit like there's some play in the rear direction.
Just a bit confused at how to determine which mount (front or rear) is bad? Looking through the forums, most people have the front go first, but mine looks ok. Can't see the rear mount at all. I'd appreciate any help diagnosing this.
Thanks.
Old Mar 16, 2010 | 09:21 AM
Dopes6070's Avatar
The easy way to figure out which ones are broken is to look for an oily fluid around the mount... I had to replace both that side mount and the front one in my RL at 80k
Old Mar 16, 2010 | 09:32 AM
vinuneuro's Avatar
From what I understand, that side mount only fails after either the front or rear mount lets go. Is that correct? The area around the front mount is visibly dry and I don't feel anything oily either. Does that mean the rear mount is bad? It's just that I haven't seen many people talking about that one needing to be replaced, and there doesn't seem to be a way to look at it without removing it.
Fwiw, the car is an 05 auto, with 45k miles. It's out of warranty.
Old Mar 16, 2010 | 09:47 AM
Dopes6070's Avatar
I would try to get the dealer to replace whatever mounts are broken under a "goodwill warrenty" at that meilage you should have no problem getting them to take care of it.
Yes usually that side mount will only fail after a front of rear mount breaks... You should be able to see the rear one with a flashlight. You can also have someone firmly hold the break pedal and lightly push the gas with the car in drive while you look at the mounts to see which one seems loose. Make sure its someone you trust LOL.
Old Mar 16, 2010 | 09:28 PM
libert69's Avatar
18psi
If your not under warranty and you need to buy front and rear mounts, Im selling front and rear mounts in the black market. They have 11k miles on them
https://acurazine.com/forums/car-parts-sale-361/04-06-5at-tl-oem-motor-mounts-suspension-767340/
Old Mar 16, 2010 | 09:31 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Call ACS. In the least, get a discount for replacement mounts. Don't just get the torn one replaced, get all 3 replaced.
If it happens later on, maybe you'll want to go aftermarket?
Old Mar 16, 2010 | 09:50 PM
vinuneuro's Avatar
I'll try to see if they'll goodwill it in it's entirety. Doubt it though. The discount will probably end up being more expensive because their labor rate will get tacked on. It's $240 for all three mounts, and I can install them myself. More than likely though only this side mounts and one of the other two needs replacing, so more like $150.
I wouldn't mind aftermarket, but this is my mom's car.
libert69, thanks for the offer.
Old Mar 16, 2010 | 09:52 PM
Yonkers914's Avatar
04Tl
oh lol i was gonna say go after market with the mounts but since its ur mothers car then go stock lol these stock mounts cant take a slight ounce of abuse.!
Old Mar 16, 2010 | 10:18 PM
Fresh23's Avatar
Just get some new excelerate mounts!!
Old Mar 17, 2010 | 05:28 AM
johnny3's Avatar
Hmmm, wonder what would have torn the motor mounts loose in "Mom's" car..
Old Mar 17, 2010 | 08:28 AM
Dopes6070's Avatar
I used to work at a dealer and you would be surprised how many odyssey vans we would get in where mom was the only one driving it and it had torn mounts... Unfortunately to make their cars nice and quiet Honda had to use really soft liquid filled rubber mounts. There is just no way for them to last as long as some of the old hard rubber ones that would go 150k miles plus. I think under 50k you should still be able to get Acura to cover them though that’s just too soon for them to fail no matter how hard the vehicle is driven.
Old Mar 17, 2010 | 08:45 AM
MyTL09's Avatar
B A N N E D
Wow I never knew those can be torn, gotta check mine
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
