TL rear A/C seems to be dead. Do they also have the resistor for that ???
Old 06-25-2015, 01:55 PM
eg-r's Avatar
As title
Old 06-25-2015, 04:01 PM
Received 8,595 Likes on 6,639 Posts
It's helpful to elaborate a bit when you post things.
I'm reading it as Rear air conditioner is dead, is there a resistor for it? Are you talking about the air conditioning not going to the rear seats? The air conditioning has ducts that lead straight to the back and there is a vent slide you can use to open and close. You can tell when its on because the two metal trim pieces along your shifter will get cold.
Can you expand on your problem so we can better help you?
Old 06-25-2015, 07:13 PM
eg-r's Avatar
When I have the car a/c on auto. I don't seem to feel air coming out from the rear a/c vents
Old 06-25-2015, 10:53 PM
Jackass's Avatar
The rear vents are generally tied to the center front vents. If the "auto" mode has the air coming out defrost or floor vents, the airflow out the rear vents will be quite low.
Also make sure the rear vents are actually opened. There is an adjuster in between the vents.
There is no actual rear A/C blower.
Will Y. (06-26-2015)
Old 06-30-2015, 10:30 AM
DMZ
Head a da Family
DMZ's Avatar
I don't think there's even an app for that!
jdm_94-07TypeS
10-07-2015 11:14 PM
Greengecko
09-16-2015 08:19 PM
lovic87
09-15-2015 06:07 PM
theinsvnity
09-10-2015 10:22 PM
dlknight
09-03-2015 07:54 PM
Quick Reply: TL rear A/C seems to be dead. Do they also have the resistor for that ???
