TL Door Sensor
Old Nov 22, 2010 | 10:49 AM
scottyrocket53's Avatar
TL Door Sensor
I was wondering if anyone else has had the same issue that I have. i own a 2006 TL and whenever someone is in the passenger seat the open door sensor will go off for a brief second when I turn left. I have checked the door to make sure that it is closed all the way and it seems to be. Anyone else had the same problem? any fixes?
Old Nov 22, 2010 | 11:18 AM
DeathMetal's Avatar
Fearless DIY Guy
Open the rear passenger doors; you'll see a rubber stopper on the door itself, this comes in contact with the door sensor. Any adjustments can be made by extending the screw in the door by a thread or two to ensure full contact during turns.
Old Nov 25, 2010 | 10:37 AM
Thanks for taking the time to answer
Old Nov 26, 2010 | 10:04 PM
Japs08's Avatar
I have the same problem with the front passenger door sensor. The light will go off when turning left and sometimes when putting arm on the arm rest too.
Old Nov 27, 2010 | 01:00 PM
Japs08, did you fix the problem? Mine is the front passenger door not the rears.
Old Mar 21, 2012 | 11:53 AM
ggallant1's Avatar
I'm having this problem on the front passenger door of my 2005 TL. Does anyone know the formal part name or number so that i can order a replacement? Planning to order from www.acuraoemparts.com
Old Mar 21, 2012 | 01:52 PM
PJ-Delray Acura's Avatar
Former Sponsor
Spoke with an Acura Tech about this. According to him, this problem is corrected by making an adjustment to the sensor or door panel. The sensor does not have enough pressure on it, there is slightly too much space between the sensor and the door when it is shut.
Old Mar 21, 2012 | 11:48 PM
frame's Avatar
I had the same problem with my passenger door. I unscrewed the sensor on the body (i think its on the body, its been a while) that gets pushed in, and folded a piece of paper a few times and stuck behind it, so it pushed it out more and make a better contact with the door then screwed it back down. Fixed in 30 seconds.
Old Mar 22, 2012 | 09:36 AM
ggallant1's Avatar
Thanks, I actually did this inadvertently. I unscrewed the sensor to see if it was hooked up to a harness to make replacing it easier (it was). Thinking I'd go to the dealership later to buy a new sensor, I put the sensor back in but didn't screw it back in as tight as it was, since I'd be taking it back out in a few hours. I drove around after that and what do you know - no more open door chimes!
Old May 19, 2014 | 07:51 AM
Applejuice1's Avatar
4th Gear
I have same exact problem w pressure on door panel and turns Did you find a fix?
Old Nov 13, 2014 | 02:20 AM
GhostK1lla's Avatar
I had the same problem on my TL and I was finding the source of the problem which was my door sensors going off showing that the doors are open which it wasnt and it happened when it rained and then it started happening after it stopped raining. I found at that by the fuse and relay there is a fire wall that leads to the outside the car which was by the driver side wheel and I reliazed that there was water coming inside the car so what I did is I removed some of the carpet and socked all the water and patched the hole and the door never showed that it was malfunctioning again.
Old Mar 20, 2016 | 09:13 AM
mazen222's Avatar
i've been having the same issue, i'll try to unscrew that sense by a thread like you guys mentionned
Old Apr 15, 2017 | 01:34 PM
dannydavila87's Avatar
5th Gear
Talking
Thanks man, i tried this and it seemed to fix the issue, will drive around a little more later to make sure its fixed.
mlody
Dec 4, 2019 02:11 PM
BIGxRED
Oct 19, 2015 10:47 PM
RobbDizzle
Oct 15, 2015 11:16 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
