Tips to remove halfshaft?
I'm in the middle of removing the passenger side halfshaft but it's been a PITA so far. Can anyone recommend a tip to getting it out? BTW, it's a 2005 TL auto.
Sorry, I should be clear on what I'm asking. I'm at the step of removing the actual halfshaft. Having a hard time popping it out. Wanted to see if there are any tips or tricks to getting it out.
Take a med. size screwdriver or chisel with a gradual taper & tap (wedge) it between the transmission case & the inner cv joint & it usually will pop right out. If you feel like you're getting the tool too tight (too much pressure) strike the inner cv joint with a good sized hammer while the pressure is on & then it will pop out, sometimes it takes some common sense about the amount of wedge pressure between the two as I suppose the trans. case could be damaged (stubborn cases) altho Iv'e changed dozens of them without a problem.
Also (don't forget) when you get the new axle in & thru the knuckle be sure & bang (tap, whack) the threaded end to seat the inner end of the axle locked back into place as it can become disengaged the first time cut the wheels backing out into the street.-- Don't ask me why I know this. Johnny
Thanks! I got the driver's side out but man the passenger side isn't cooperating at all.
STL TL-S
09-23-2015 08:52 PM
