Is it time to change plugs?
Old Apr 24, 2011 | 05:31 PM
SUPERCAPRICORN's Avatar
Smile Is it time to change plugs?
I have an 05 TL auto with 74,000 miles. Lately the car doesn't accelerate as strongly as it used too. Whenever i used to floor it it would rev hard and speed up like a beast. Its still fast but hesitates a little now. Not as sharp. First thing to come to mind is the plugs since there the originals. All maintenance has been done according to the schedule. Oil changes,tranny fluid 3x3, filters etc. Any insight would be appreciated.
Old Apr 24, 2011 | 06:22 PM
tupacboy's Avatar
my first thought was fuel injector...
Old Apr 24, 2011 | 07:19 PM
TheDingo's Avatar
Resident Dingo
It's a good start to troubleshooting the issue. Simply pull them out and take a look at them, you'll know immediately if they need to be changed. It's so easy to take them out, it almost doesn't make sense to start there when figuring out an ignitions system issue.
Old Apr 24, 2011 | 08:57 PM
nfnsquared's Avatar
I seriously doubt it's the plugs, assuming they are OEM iridiums.
Might be the APP sensor (although it usually throws a code).
Might just be worn out from all the "flooring" you've been doing.
Old Apr 24, 2011 | 10:15 PM
mau108's Avatar
if its an auto the transmission could be getting "tired" and just not as efficient at putting the power down as it used to.
Try changing out fluid and switches?
Old Apr 25, 2011 | 12:42 AM
BAGII's Avatar
I think plugs is your best bet. they could definitely cause a slight hesitation under heavy load.
Old Apr 25, 2011 | 01:52 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Sounds like your engine is ready to explode.
Old Apr 25, 2011 | 02:20 AM
csmeance's Avatar
Try doing the transmission algoritym reset and as well try running some fuel cleaner through the system. I've used Redline SC-1 and it's been amazing! Also the gas you use can really affect the car. I've noticed that if I use Shell gas my TL is quite a bit more peppy and responsive versus other gas. Maybe the additive pack they use or the lack of the 10% ethanol may be the cause.
Old Apr 25, 2011 | 08:27 AM
TheDingo's Avatar
Resident Dingo
lol damn.
Old Apr 25, 2011 | 02:59 PM
jda123's Avatar
Dogmatic Dinosaur
You using 91 octane still?
Old Apr 26, 2011 | 05:38 PM
Thanks for all the reply's. Yes i use 93 octane Exxon. I just dropped in some redline fuel system cleaner and ill check the plugs. As for the tranny algorithm reset i don't know how to do that. Some feedback would be helpful so i can try it.
cycdaniel
Dec 17, 2019 10:58 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
PortlandRL
Sep 14, 2015 12:01 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
NSolace
Sep 3, 2015 08:14 PM
