Throttle surge gone
Throttle surge gone
I was discussing my throttle surge issue with another forum member at a meet in Dallas, and seeing he had "dead pedal" a couple of times like me as well, he said he just replaced the accelerator pedal sensor. I talked to a couple of Acura mechanics and they said it was an issue on the TL cars in hotter areas because of where it is placed on the firewall (in a particularly hot area). They said the TSX has the exact same sensor (same part number), yet they don't have the problem. So, I ordered a new one and put it in today. I added some of that aluminum foil tape stuff for ducting to help shield it from some of the heat, and I also adjusted the 2 nuts on the throttle cable to take almost all the slack out of the cable (there was quite a bit)...
Needless to say, the throttle surge is gone (did 2 hour road test), and the throttle and pedal response is TONS better. These are the pics of my work...
well, wrapping it will only delay the heat transfer rate, but final temperature will still be the same.
a more permanent solution(if this APP sensor is indeed the cause) would be to relocate it to a cooler location, perhaps near the front of the engine bay by the radiator fans
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
