Throttle surge gone
Old Aug 17, 2013 | 02:44 PM
EvilJoker's Avatar
All Around Klown
Throttle surge gone
I was discussing my throttle surge issue with another forum member at a meet in Dallas, and seeing he had "dead pedal" a couple of times like me as well, he said he just replaced the accelerator pedal sensor. I talked to a couple of Acura mechanics and they said it was an issue on the TL cars in hotter areas because of where it is placed on the firewall (in a particularly hot area). They said the TSX has the exact same sensor (same part number), yet they don't have the problem. So, I ordered a new one and put it in today. I added some of that aluminum foil tape stuff for ducting to help shield it from some of the heat, and I also adjusted the 2 nuts on the throttle cable to take almost all the slack out of the cable (there was quite a bit)...
Needless to say, the throttle surge is gone (did 2 hour road test), and the throttle and pedal response is TONS better. These are the pics of my work...
Old Aug 18, 2013 | 11:24 PM
vr6vdub's Avatar
hmmm...interesting
I've noticed that it doesn't happen with the A/C running because of the fan running constantly. I might have to try this out.
Old Aug 19, 2013 | 02:54 AM
paperboy42190's Avatar
well, wrapping it will only delay the heat transfer rate, but final temperature will still be the same.
a more permanent solution(if this APP sensor is indeed the cause) would be to relocate it to a cooler location, perhaps near the front of the engine bay by the radiator fans
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
