Tachometer needle keeps bouncing
Old Apr 23, 2013 | 12:08 AM
Cody1277's Avatar
what's up guys... i need help bad!
My tachometer needle keeps bouncing and the car stutters, especially when driving up hill. feels like the car is about to die on me....car is 06 TL AT supercharged.... any help will be great, thanks
Old Apr 23, 2013 | 01:04 AM
4drviper's Avatar
is it just the needle or is your engine rev bouncing up and down...?
electrical gremlin?
or AT slipping like cray
Old Apr 23, 2013 | 01:15 AM
Cody1277's Avatar
the whole car stutters like it's running out of gass...and rpm needle bouncing like crazy
Old Apr 23, 2013 | 01:54 AM
paperboy42190's Avatar
could you be misdiagnosing it for a misfire? any check engine lights?
Old Apr 23, 2013 | 02:10 AM
Cody1277's Avatar
i was thinking misfire too... no check engine lights.... should i change out the spark plugs? flush out the tranny fluid?
Old Apr 23, 2013 | 07:06 AM
PLEASE dont take this the wrong way...
but you're supercharged and not really sure how to diagnose?!?!?!
please tell me you didnt install the supercharger your self?
these trannies are glass.
if you're pushing 50-60hp OVER stock, you're in for trouble.
matter of fact; the member UA6 supercharged his 06 auto and shortly after that went through 2 trannies.
Lets start off by giving the history of your car.
who installed it?
when did this start happening?
did you install any precautionary measures? like tranny cooler; meth, etc?
Your sig indicate that you have the high boost pulley.
without giving us any detail; all we are doing is guessing your problems.
you need to be clear an concise on whats happening with your car.
Old Apr 24, 2013 | 09:42 PM
Cody1277's Avatar
Acura installed the supercharger. had it tuned... bought the car in colorado, never had problems until i moved to maryland. only have 42000 miles on it ..... car is in the shop now, will give an update when i get it back.... thanks for the help though
Old Apr 25, 2013 | 08:27 AM
ZOMGVTEK's Avatar
Was the car 'tuned' in Colorado presumably? Any idea what they used to tune it?
You don't see any problems with such a dramatic altitude drop? It's most likely running really lean.
Old Apr 25, 2013 | 07:38 PM
roof2006's Avatar
Good point. My guess was "sounds like a fuel delivery problem." Particularly since it only happens under heavy load (going up hills.)
Could turn into a big problem. With forced induction, "running really lean" is baaad...
Feb 25, 2020 09:57 AM
TSX 09
2G TSX Problems & Fixes
Sep 23, 2015 08:25 PM
tiresmokinV8
Sep 15, 2015 09:10 PM
brandnewcolony
Sep 12, 2015 10:39 AM
gavriil
Jan 3, 2004 02:55 PM
