Sun Spots on Dash. Our first TL
Old Nov 20, 2009 | 09:59 PM
MY04SilverTL's Avatar
Just purchased a 2004 Acura TL 96k, very clean and quiet. How ever now in the sunlight, we have noticed that the car has sun spots mainly on the passenger side of the dash. Do they make a compound, or polish to bring out the spots, or am i going to have use lots of armoral cover it up? By the way this site is very informative for new owners of the TL side. Thanks Caleb
Old Nov 20, 2009 | 11:09 PM
Will Y.'s Avatar
Registered but harmless
Do a search here for "ashy dash"-- it'll bring up a host of threads about the issue you have.
Fix the problem by:
1) using a good vinyl cleaner -- the Honda stuff apparently is pretty good-- to wipe the dash (or woolite solution as described in other threads) and remove the outgassed materials that show as spots on the dash, and
2) applying 303 Aerospace Protectant or similar vinyl protectant onto the dash with a towel or applicator pad.
Welcome to AZ.
Old Nov 21, 2009 | 06:23 AM
Turbonut's Avatar
Keep the dash well "lubricated" to ensure longevity. Everyone has their favorites, but I use Turtle Wax F21 super protectant with sun stop. Just spray it on a cloth and apply to the dash. If you try and spray it on the dash, any solution wil get on the inside of the windshield, or other unwanted areas.
This may be the results if not:
https://acurazine.com/forums/3g-tl-problems-fixes-114/my-cracked-dashboard-ordeal-730775/
Many threads on the subject.
Old Nov 21, 2009 | 01:09 PM
Bender's Avatar
hahaha not to burst your bubble but your gonna notice all sorts of build quality issues, so get ready to live with it.
Old Nov 21, 2009 | 04:59 PM
04TLinSYR's Avatar
Fix the problem by:
Welcome to AZ.
303 Aerospace Protectant rocks. You may have to use a couple of applications to get the dash back to normal. I use the stuff every 4 months or so and my dash looks new (04 TL with 100K). Best place to get this stuff is a boating supply store like West Marine. I use a mixture of 1 part Woolite to 6 parts water to clean the vinyl.
Old Nov 22, 2009 | 01:52 PM
csmeance's Avatar
these sun spots you are seeing is a chemical that is migating through the vinyl; this is normal for the 3G TL. The solution to it is to first clean the dashboard. The best way to do this is with a solution, 1 part woolite, 6 parts water. Put the solution on a cloth and wipe down the dash with it. Follow up with a damp cloth and dry. Then wipe again with a damp cloth and then dry.
You may need to repeat this again depending on if it's ever been cleaned before, I'd recommend it.
Then you must put the finishing touch on it to restore the color and make it look better. Take some 303 Aerospace Protecant and spray onto a cloth. Then wipe down the dash. Let it sit for a few minutes and then wipe off any excess with a dry towel.
(303 will protect it from UV damage as well as moisturizing the surface since it's water based)
You can use 303 on the door seals, weather stripping, rubber and any plastic and leather! It's a great product. Just remember to clean all the surfaces first!
Old Nov 22, 2009 | 02:12 PM
dwb993's Avatar
http://www.303products.com/
Old Nov 23, 2009 | 12:21 PM
Bender's Avatar
Yea don't use armor all on your dash if you want it to last.
tsx_boy
Dec 13, 2019 08:33 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
