Sudden electrical starting issue
Old Feb 7, 2019 | 07:34 PM
Tunabass's Avatar
05 MT TL. I stoped to get gas today and after I filled up I went to start the car and nothing. When I turn the key all sorts of dash lights flicker fast and a really quick ticking sound accompanies while I turn the key. When I release the key it stops. Its an electrical ticking not a starter/battery sound. This occurred literally after no symptoms for the 6 months I’ve had it to instantly nothing. Luckily I can pop the clutch from my driveway to get it going and everything works fine till I turn it off. Any ideas please?
Old Feb 8, 2019 | 11:14 AM
How old is your battery replace it!
Old Feb 18, 2019 | 06:52 AM
DMZ's Avatar
DMZ
Head a da Family
Also, check the + battery cable. At this age, it might be corroded internally where you can't see it.
Old Feb 22, 2019 | 02:42 PM
ATLPanther's Avatar
Seconded. I had the exact same issue with my 08 Type S. The positive battery cable was internally corroded and the electrical connection was overwhelmed when attempting to start the car. I almost guarantee you that's what's causing your issue.
Replacement isn't hard or expensive. Just get the new cable from Delray Acura. Took me about 10 minutes to remove the old one and put in the new one.
celsoglima
Nov 30, 2016 03:34 PM
Jerzyboi
Oct 20, 2016 10:28 PM
bensgig
1/2G MDX (2001-2013)
Jul 19, 2016 09:38 PM
anthongy817
1G TSX Problems & Fixes
Jun 29, 2010 11:07 PM
sprucha
1G CL Problems & Fixes
14
Jun 9, 2006 04:37 AM
