Subframe Dropping ?
Old Oct 26, 2013 | 06:43 PM
mattymattB's Avatar
From Around The Way
Subframe Dropping ?
Would anyone with experience or knowledge please give a break down or point me in the direction or make a video LOL, on how to drop the subframe exactly and what it means? I need to install a new Rack & Pinion and figured Might as well upgrade the FSB as well. I've done many repairs on my car before so im not a complete, idiot . Just enough not to know how to do this. If any cool guys could school me , I'd appreciate it a whole lot. Thanks a mill
Old Oct 26, 2013 | 09:18 PM
Slpr04UA6's Avatar
-------Tim-------
Here is some info.....
https://acurazine.com/forums/3g-tl-2004-2008-93/replace-front-sway-bar-diy-859976/
Old Oct 26, 2013 | 09:21 PM
JJH's Avatar
JJH
Lot of work to drop the subframe. Lower control arms, motor mounts, etc.
Old Oct 26, 2013 | 09:27 PM
^would be a pretty cool weekend project.
and I mean, ALL weekend.
Old Oct 26, 2013 | 09:42 PM
mattymattB's Avatar
From Around The Way
You mind elaborating or pointing me somewhere i could find out ? I read the thread suggested above but it isnt clear....Any youtube clips...I have plenty of time as i just got laid off and am on unemplment and am not trying to dish out any dough to pay someone for my ignorance. So i gotta remove the lower control arms.....remove ALL the motor mounts ? ....From where exactly does the subframe get DROPPED ?
Old Oct 26, 2013 | 09:44 PM
mattymattB's Avatar
From Around The Way
Thanks for the encouragement
Old Oct 26, 2013 | 10:04 PM
JJH's Avatar
JJH
Look under the car. Remove everything from the subframe. It's pretty self explanatory. You'll have to get an alignment afterwards. Replace your motor mounts too while it will be easy.
Old Oct 26, 2013 | 10:21 PM
mattymattB's Avatar
From Around The Way
Ok thnks...The other part of my question was..So everything is removed from the subframe....then what...How do you initiate to where you begin DROPPING the sub frame..Does that automatically happen once everything is removed ?
Old Oct 26, 2013 | 10:33 PM
JJH's Avatar
JJH
yes lol, just look and you will see
Old Oct 27, 2013 | 01:13 AM
paperboy42190's Avatar
after you remove the motor mounts and control arms, theres a couple big subframe bolts on the bottom you'll see on each corner. should be somewhat obvious. and definitely make sure your tools are up to the task of removing those heavily torqued bolts
im not sure how you're planning to support the subframe but its going to be heavy and i dont think a regular car jack will hold it balanced
Old Oct 27, 2013 | 08:11 AM
JJH's Avatar
JJH
Yeah, I would really want a lift to drop the subframe. It's not my kind of DIY project at all.
Old Mar 15, 2019 | 01:52 PM
TacoTom1967's Avatar
You can DIY this!
Actually, you can do it without a lift. I got two jacks and two 18”x12” furniture Dolly’s, I added some 1x4’s to the middle of the Dolly’s and balanced them on the jacks, with one on each side of the car. Raise the jack/dolly’s Up to the subframe, remove the bolts, slowly lower the subframe lowering each side a little at a time going back and forth on each side until you get it down. Make sure you mark the position of the subframe to the body and the subframe stiffeners to the subframe before you unbolt them.
Old Mar 15, 2019 | 05:04 PM
Turbonut's Avatar
How to remove steering gearbox-Section 17 pg 29
http://www.nnstudios.com/azine/Acura...e%20Manual.pdf
Old Mar 15, 2019 | 06:52 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
You know you are responding to a 5.5 year old thread, right?
Old Dec 18, 2020 | 01:46 AM
Dean Simmons's Avatar
Thanks for the tips guys. As I am planning to do this very thing to a 2005 MDX, it's great to know there is the possibility of doing this safely and to have our information available to all viewers ^_^
Old Dec 18, 2020 | 03:54 PM
Midnight Mystery's Avatar
Null and proud of it
My mechanic said it takes him 4 hours start to finish.
Keep in mind this is in a dealer's shop, on a lift and with an experienced Honda tech.
Usmcgrunt47
Oct 13, 2023 09:35 PM
emailnatec
29
Sep 28, 2018 04:27 PM
bluetl04
Aug 16, 2016 02:49 PM
us285126
Oct 2, 2015 02:03 PM
4drviper
Sep 23, 2015 07:42 PM
